1. Have my PC and WLAN Box in the "working room"; connected AirPort Express to the WLAN Box, Installed Airport Installer (version 5.6.1.2)
2. went throgh the installation process, installed iTunes, There I could finde the AirPort Express Box,
3. Though I moved the box to my living room (no more direct network connection to WLAN box), Box showed still a green lamp
4. linked the AirPort Express Box with the B&O (Beosound 3000) via AUX
5. Can choose on iTunes between sound on PC or Airport Express (choosed both)
6. Installed remote App on the IPad and everything works fine
Now I wonder, if i can connect directly to the amplifier without the PC?
1. installed AirPort App on the IPad
2. In the app it shows a green internet connection, but searching for AirPort Express it does not find the box
Has anybody a clue what could be the reason for this?
Hallo Lawrence, have the 802.11n Wi-Fi. The whole package works well via the Remote App on the IPAd. Only thing is have to have my PC on.
put a picture also in the media folder of my set up
went into the Airport software again:
Airport - > wireless
there I found following options: (my translation from German)
- create new wireless network
- connest to wireless network (that´s what I chose)
- extend a wireless network
- out or finish
Hallo Lawrence, yes i followed 1 - 4 before already. tried it again. The interesting is in the grey field i see in the middle 5 circles. Underneath i guess i should find the choices you described. but there is nothing. no drop down field to choose. But I hear sound on the ipad.
Horst Lederer:went into the Airport software again: Airport - > wireless there I found following options: (my translation from German) - create new wireless network - connest to wireless network (that´s what I chose) - extend a wireless network - out or finish
BeoNut since '75
morning elephant. can i go in the set up and change the option leaving the set up like this. currently i have no network connection to the WLAN box, because my AirPort Express is in the living room?
went in the setup again and changed to "Ein drahtloses Netzwerk erweitern" (extand a network)
But I got an error during update (code 10057)
Does your Airport Express show a solid green light? Is the issue just from the ipad or also from iphone or directly from Itunes?
