at present I have a Beosound Overture as the hub of my masterlink system. I have at present 5 zones. I would like to upgrade to a newer hub other then the overture in the system. I see the Beosound 4 is available as well as the Beocenter. Do I have other options that I could use a source for my master link system? Could I use an Essence or a Beosound 5? Maybe add a Playmaker??? I am looking to get music from my computer which would be nice. But not 100% necessary. What are my options with a masterlink system. Can I still add a new master Hub? Does it have to be B&O?? Thanks!!
`Congratulations on a great setup.
A Beosound 4 would easily slip into place.
It would give you a CD, FM radio, DAB or DAB+ (if it ha been chipped), SD card (this is really great for recordings from radio and/or a special collection of MP3 playlists). or AUX in from either a beogriam, beocord, PlayMaker. Gammon (see Mille's latest post), or Airport Express, or even a non-B&O TV's headphone output.
I presume (no time to check, sorry) the Overture has an AUX in. In which case the AUX in options already exist for you !
To get music from your computer either use the AUX in approach from its headphone output ... or get a BeoPort to connect to the master link.
BeoNut since '75
Do any news n B&O options exist?
striker27:Do any news n B&O options exist?
striker27:at present I have a Beosound Overture as the hub of my masterlink system. I have at present 5 zones. I would like to upgrade to a newer hub other then the overture in the system. I see the Beosound 4 is available as well as the Beocenter. Do I have other options that I could use a source for my master link system? Could I use an Essence or a Beosound 5? Maybe add a Playmaker??? I am looking to get music from my computer which would be nice. But not 100% necessary. What are my options with a masterlink system. Can I still add a new master Hub? Does it have to be B&O?? Thanks!!
I was looking for some Non B&O options that may be available but the NL/ML convertor does seem like a possibility. What model number is it? Is it still available? I do not see it on the B&O web site.
Lots of good ideas here!!!
striker27:I was looking for some Non B&O options that may be available but the NL/ML convertor does seem like a possibility. What model number is it? Is it still available? I do not see it on the B&O web site. Thanks Lots of good ideas here!!!
