I could use some input on the non playing of disks on a Beogram 3300 cd player
The disk spins briefly and then turns off and displays a ?
It been a great unit and I would like to continue using it to play the CDs still on hand
JC
JPJS: I could use some input on the non playing of disks on a Beogram 3300 cd player The disk spins briefly and then turns off and displays a ? It been a great unit and I would like to continue using it to play the CDs still on hand JC
Sounds very similar to the symptoms seen on the CDX/CDX2 where broken solder joints are the problem.
Assuming you've tried cleaqning the laser lens?
Dave.
My CD3300 had the same issue. It was a capacitor on the servo board, and one bad solder joint.
Welcome!
Jacques
