How badly is the sound degraded, if at all, by plugging the standard B&O speaker cables in & running them w/o plugging the Pentas into the wall?
ok how do you bypass the amp?
How do you remove it?
Using Jadis JA500s
Hallo John Kercheval
http://www.hifi4all.dk/forum/forum_posts.asp?TID=42140&KW=B%26O&PN=0&TPN=2
Use Google translator
HUH????? Greek to me! :) Simple & in English?
You want it simple, remove 5 nuts under the base, remove the base, another 5 nuts to be removed, next the amp incl. leads and last, 5 rods. Simple right?
Brengen & Ophalen
THANKS! I'll give it a try!
Click.
Thanks that's great I'll keep you guys posted!
Yes please remember to tell us.
Regards Peter Pan
@Peter Pan, your graphics are fabulous!
Thank you Leslie
Remember Christmas atmosphere!
https://www.youtube.com/watch?v=pqKb1OGpDjo
