I have a Biomaster 5000 bought in 1985
I am wondering if its possible to connect it to my Airport express, so I can use it with a iPad or iMac and if so what is the best way of doing so. I also have the Biomaster 5000 control panel
thanks for your help
Mike
Yes it is.
We have that set up in daily use in the family.
We connected the Airport Express via a cable to the second Beocord connections - so on the control panel we press TP2 to access the sound from the AE. and Airplay to the AE using our iPhones.
The cable you will need should have an earphone jack for attaching to the AE, and a DIN plug at the Bombaster end.
BeoNut since '75
Elephant
thank you very much for your help and reply
Have a wonderful Holiday Season
