Hello and greetings from germany...
i am a great fan from the B&O App for iPhone/Ipad...
You need the master link "Gateway" to use it and so i hope there will come a new connector for the V1.
I hope so much that in the near future it will be possible to use this apps also with the V1!
V1 doesn't have masterlink and that makes it incompatible with that application unfortunately. Perhaps it will be possible to control V1 from iOS in some other way (My samsung tv has a remote-app for iPhone but I never use it).
And they also market the possibility to put an Apple TV inside V1 for use with AirPlay etc so I think that might be it(?)
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Beoworld app with direct photo upload and emoticons.
wtlc2zpx:You can use an UPNP server app on your iPhone to stream content to your TV without Aiport!
