Beocenter 7700 acoustic feedback rumble
This post has 4 Replies | 0 Followers
Christian Christensen
Stockholm
Posts 512
Christian Christensen Posted: Sat, Dec 20 2014 6:17 PM
At not acceptable level. the entire system seems sensitive
light taps with my finges on the system is hearable in the speakers.
The system feedback very easily
transport screws loosened, of course.
It seems like the system is horisontal.
BC stand on the standrd B&O furniture.
Speakers are MC1200
Any tips ?
My re-capped M75 are my precious diamonds.
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Sat, Dec 20 2014 6:22 PM
Maybe the leaf springs on the suspension need adjusting...
Stockholm
Posts 512
yes maybe, are they to have a certain adjustment ?
My speculation is if any caps in the RIIA section has collapsed, thinking of that there should be a traditional rumble filter on 15 Hz should be part of the design.
When I turn up the colyme there is a constant rumble in the background that is just waiting to turn into feedback
Lee
Posts 734
Lee replied on Tue, Dec 23 2014 2:59 PM
The platter needs to be level with the plinth for the suspension to work properly. Too high or low and the damping effect will disappear.
The rumble could be caused by a bad bearing... try a couple of drops of sewing machine oil in the centre bearing.
Stockholm
Posts 512
Thanks, Lee, problem solved.
It was the suspension screws.. I spend alot of time with them today, to figure them out
They need to be quite tight . the weight of the platter and a record pushes it down.
Now playes wonderful loud with a new pressed 180grams from Canada, Leornad Choems last album
Page 1 of 1 (5 items) | RSS
