BC2 & Beolink & A. AUX
This post has 8 Replies | 2 Followers
Michael
Sweden
Posts 2,578
Michael Posted: Mon, May 21 2012 7:45 PM
Hello guys. I have a question. A friend of mine has a BC2 connected to a BV5 in the main room and two beolink passive for outside speakers and bedroom speakers.
i connected an airport express to the aux in on BC2´s socket unit and from the main room I can select A.AUX. But trying to do so from the link-rooms doesnt make anything.
I have tried adding Phono and tried A.tape also but none of them seems to work, not N.Radio either that someone suggested. Even tried an older Beolink 1000 (shift+radio) did not work either :).
Is the Beolink passive´s firmware just too old? If I start the main room on A.AUX I can then power up the linked rooms so it works but not as good as it could.
Vienna
make an educated guess
Posts 1,090
Vienna replied on Mon, May 21 2012 10:40 PM
Michael:
Very likely - BeoLink Passive (or Active) need SW 1.5 (current version is 1.6) to support "A.AUX"
Michael
Sweden
Posts 2,578
Michael replied on Mon, May 21 2012 11:10 PM
Vienna:
Michael:
That is a bit strange, but I have heard it before unfortunately. They are just four years old and are installed behind a wall. Is it possible to upgrade them yourself?
Michael
Sweden
Posts 2,578
Vienna:
Michael:
Vienna
Posts 1,090
Vienna replied on Tue, May 22 2012 12:12 AM
Michael:
SW 1.5 has been released end of the year 2008 -  few month after your purchase ...
Michael:
Depends on your skills & tools - you'll have to replace the SW-EPROM .
Michael
Sweden
Posts 2,578
Michael replied on Tue, May 22 2012 12:19 AM
Can I donload the firmware somewhere and flash the eeprom myself? Seems unneccessary to buy a new chip if I can just read and reprogram :)
Reinhard
Berlin
Posts 4
Reinhard replied on Tue, May 22 2012 11:04 AM
Hello
I have the same Problem with the BC2 and Ml/MCL Converter. BC2 has SW 1.3 and ML/MCL Converter has SW 1.4 .
My Question has anbody done the SW Update (performed by a dealer) and solved the described problem ?
Thanks Reinhard
[<b>edited by:</b> rsy at 5:47 PM (GMT 0) on Fri, May 25 2012]
Note : I got an answer from BEOCARE after sending an Incident ticket about the problem. Update the SW of the ML/MCL Converter should fix the problem. Not done yet but I will inform you if I have done the upgrade (done by my dealer)
Cheers
Reinhard
Reinhard
Berlin
Posts 4
Reinhard replied on Tue, Jul 10 2012 11:47 AM
Hello,
now I have upgraded my firmware to 1.64 it works.
I have to use LINK SHIFT RADIO to select the A.AUX input of my BC2 from any LINK-Room
The upgrade cost me 120€
Hope this helps
Reinhard
BeoHut
Posts 482
BeoHut replied on Tue, Jul 10 2012 8:50 PM
I have done the upgrade to SW 1.6 on the ML/MCL by my dealer.
Aux can now be played in every linkroom, including Nradio and Nmusic.
This is the solution and really works good.
Page 1 of 1 (9 items) | RSS
