Hello All
I have recently acquired a defect beogram CD6500. It so happens, that the CDs are trying to be read, but suddently the CD6500 gives in and stops.
I'v looked a little around in the forum, which seems to conclude, that the capacitors might be defect.
My problem is, where do I find these capacitors (if they are being manifactured anymore), or is there similar rated capacitors I could be using instead?
Regards Rasmus
I apologize for the repost. For some reason to post were created even though i only made 1??
