Installing a Technisat HDFV receiver to the MX7000
petsnaturally
Posts 2
petsnaturally Posted: Tue, May 22 2012 12:12 AM
I have just purchased a Technisat HDFV Freeview HD Digital Receiver to attach to my MX7000 TV.
I have connected it via a scary plug to the AUX 2 input on the TV.
The receiver is supposed to launch automatically and open an install dialog box on screen - but nothing happens when I plug in.
Does anyone have any ideas as to what I may be doing wrong ?
Regards
Peter
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Tue, May 22 2012 7:24 AM
Hi and welcome to Beoworld !
You mean that you don't get any picture of your Technisat on TV ?
You connected your Technisat to AV2, so you have to configure your MX7000 to use AV2 for V.TAPE. This is done via MENU. If it's configured right, then you can press V.TAPE or V.MEM on your remote to power on your MX and switch to AV2.
Hope this helps.
Regards
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
petsnaturally
Posts 2
Thanks Martin
I had configured the MX7000 to everything but V-Tape - will try again
Regards
Peter
Page 1 of 1 (3 items) | RSS
