happy x-mas,
I use Apple TV to stream music to my BV11 (Apple TV associated with the DVD button/source). This works well as before with my earlier BV10.
However, with the BV10 I could use "AV" and then "DVD" to only get the sound, i.e no picture as intended.
With the BV11 however this doesn't work anymore: I always get the Apple TV screen as well. (possibly related to the video/audio option mode?)
Any suggestions ? (my wife insists on having the screen off whilst just playing music....)
Rene
You'll have to mute the screen/the picture manually = 'P.Mute' from the Beo4!
The function you are looking for is "picture mute", it should be under 'list' on you Beo4.
THANKS !!!!!!!! Works like a charm.
my wife just cheered !
