Hi all...I first must add that I had never heard of Bang & Olufsen until last week...I am not a big time audio phile and live in a small fairly remote town so please forgive me...lol
A woman brought in a couple of units last week and asked if I could do some research on them..get them tested, check to see if they worth repairing etc. I was quite impressed with the quality of these components and couldn't believe how much the one (Beomaster) weighed.
ANyway, I got them both powered up..
Beomaster 5500Beogram 5500Now I am wondering if it's possible at all to test these out without a remote?
If not...can you tell me what remotes may work for these, including any cheap brands..or Beo brands so I can keep an eye out for her.
She is very financially challenged (like many of us up here) so I doubt buying a $100 remote is even an option for testing these. They came from a family members estate (they probably had no idea what the remote was and sent it off to the charity place...errr..lol)
Thank you in advance...just opening these units up and looking at the quality has made me a fan....lol
BeoNut since '75
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
The Blink 1000 handset works fine indeed. I use it everyday with my BM 5500.
But you can't access everything. For instance, no tone controls!
Jacques
Beo 4 can also control BM 5500. But when you connect Beogram and push play BM 5500 should switch on and play If sound is dead at speaker connections 1 try connections 2. Connection 1 can fail because off faulty mute relay (easy fix).
