new member! trouble with a beocenter 7000
constanceB
Posts 3
constanceB Posted: Sun, Dec 28 2014 12:45 PM
Hello,
I have a beocenter 7000 for few years now. It was working properly until few months ago. Now, when it starts (tape, tuner or turntable) it turns off on its own after few seconds, minuts or sometimes it can be hours.
Does anyone know what can I do and where is that coming from?
Thanks for helping!
Constance
solderon29
U.K.West Midlands
Posts 764
The unit has fault detector,and is designed to shut down to self protect itself.Something is amiss and needs to be identified.You need help from someone with B&O expertise,a usual repair place would probably struggle.Have you checked the Dealer list on site for those with service facilities near you?
The good new's is,in the right hands,it need not be an expensive fix.There are several small components that become intermittant due to oxidation etc  with age.However,someone with experience would be able to sort this.
constanceB
Posts 3
constanceB replied on Mon, Dec 29 2014 11:25 AM
Thank you very much for your help!
I will check the dealer list or contact BO after-sales service!
Constance
Page 1 of 1 (3 items) | RSS
