beomaster 7000 backup battery replacement
nitro2
Posts 34
nitro2 Posted: Tue, May 22 2012 7:36 PM
Hi forum ,
Can anyone please advice me ,
i would like to change the backup battery on the processorboard in my beomaster 7000.
What is the correct procedure to do that without the risk of loosing the stored settings in the static ram .
nitro2
B&O , ......and some more
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, May 22 2012 8:21 PM
You WILL lose the info.
Adding external voltage across the cell is not recommended, it can (and will probably) explode
and that's not a pleasant experience.
nitro2
Posts 34
nitro2 replied on Tue, May 22 2012 9:11 PM
Thanks Martin ,
as i don't have hte official service manual ( or a copy of that ) , is there a described procedure to get the info programmed back into the static ram ??
nitro2
Dillen
Posts 13,191
Dillen replied on Tue, May 22 2012 9:33 PM
The service manual can be downloaded from our main website. A minimum membership level of silver
is required but it's easily worth the small membership fee and we would appreciate the support.
There's not a lot to it if I remember correctly. The only thing I would like to say is that I recommend
you do it with no speakers connected since you have no idea what the settings are after replacing the
cell, and that includes the volume setting. Don't ask why I feel the need to tell you this.
Laughing
nitro2
Posts 34
nitro2 replied on Mon, Jun 11 2012 8:40 PM
martin , thanks fot your support ( as always )
Volume will be preset to 26 as far as i understood , all audio settings will be gone , no stations in memory anymore , BUT..........
Is there anything more stored in that ram , i have read somewere ( long time ago ) there was something with the tuner 'offset "or so ????
nitro2
Dillen
Posts 13,191
Dillen replied on Mon, Jun 11 2012 9:39 PM
I don't remember setting tuner offsets in a BM7000. Some of the Beocenter models have the need but I don't
think the BM7000 does.
It's all in the service manual. Nothing to be afraid of.
Of course, the new battery must be replaced (soldered in) at an antistatic workplace to prevent static discharge damage.
nitro2
Posts 34
nitro2 replied on Tue, Jun 12 2012 3:59 PM
Thanks martin ,
battery ordered , manual printed , soldering iron switched on.........................ready to go.
thanks Smile again
nitro2
BeoMedia
Posts 100
BeoMedia replied on Sat, Apr 13 2019 8:02 AM
Hi!
I am due to replace the backup battery on my BM7000. How did it go for you? What did you have to reprogram after you replaced the battery, did you experience tuner offset?
What data was lost please?
Thanks BeoMedia
nitro2
Posts 34
nitro2 replied on Sat, Apr 13 2019 10:55 AM
i had no adjustments to do , all worked well .
i prepared everything so the time without power was as short as possible ( don't know if that effected the swap ) .
i remember getting the battery itself  is a bit of a problem
Page 1 of 1 (9 items) | RSS
DigiCert Secured Site Seal
