Atlona matrix anyone?
mjmedlo
Posts 922
mjmedlo Posted: Tue, Jan 6 2015 1:31 AM
Is anyone using a matrix switcher?
I was told 500 for the matrix key.
What did you all pay??
leosgonewild
Helsinki, Finland
Posts 2,373
I am using one from Gefen. I just wrote a question about some issues I have with it.
What are you going to use it with? The ones from gefen are getting fairly cheap nowadays.
Steven_London
Posts 51
Just added a matrix to my system before Christmas and paid my dealer £200 for the activation key for the BV10. Quite a lot of cash for a small number which he entered on the TV for me. The matrix does work very well and the picture quality excellent
badgersurf
Posts 539
Why do you need a key to activate the use of an HDMI matrix with a Beovision?
tompa
Posts 64
tompa replied on Tue, Jan 6 2015 11:34 PM
i think i pay about 240 euros / product
and the key needs for open up matrix funcionalty on older Products like bv10,beosystem 3, and bv7 (with bsys3)and bv8-40
and some early beoplay v1 , on  bv11,beosystem 4,avant it's included
Steven_London
Posts 51
The key is to allow the older BeoVisions to control any source on the matrix in a similar way to controlling PUC sources using a Beo4/5/6 remote. It does work very well, my only complaint is that everything has to be powered up because the Power commands are not passed to the products, like when swapping sources on the TV itself.
You can, I guess, control the matrix without the key but would have to have an Atlona IR eye mounted on the TV to send the control codes back to the matrix, I wondered if these could be programmed into the Beo6 for products which did not support the matrix by default. I couldn't see why not but it was easier to pay the money and get the B&O supported solution.
claudiu
copenhagen
Posts 193
I have been paying €200 for each key.
think it's a pretty crazy asking for €200 after you have bye 2-3 television for €20,000.
 should've been a service exactly like it on beovision avant ,beovision 11.
And the saddest part is my b&o dealer apologized for having me paying this  money .
claudiu
copenhagen
Posts 193
Griebel
Posts 416
Griebel replied on Sat, Jan 10 2015 12:57 PM
Paid 375€ for the Atlona matrix activation key. My dealer ask for it once I had purchased the matrix Super Angry
Page 1 of 1 (9 items) | RSS
