Recently my Beovision 7-40 started showing horizontal lines starting in the upper left part of the picture and fading across the entire screen towards the right. I have attached a picture.
Has anyone experienced this behavior and solved the problem?
Do you have the DVB-HD module installed in your BeoVision 7?
What version of BeoVision 7-40 do you have?
Regards Keith....
