Hi
I am the proud owner of a Beovision avant 55th
But the joy has a bad side.
I experience some buzz noise from Beovision Avant own speakers. Is it something other also experiencing?
It is all soundprograms, even at mute. As long there are image on the TV.
Kind Regards Pavia
Welcome to Beoworld. If it was other speakers attached I'd say change cables but as it's the Avants own speakers that have a fault (as they should not buzz), then first step is to get the dealer you got it from to sort it out under warranty.
Dave.
Hi Pavia,
Do you still have this problem?
Cheers
-geoff
Hi Geoff
Yes i still have the buzz problem
Kristian Rasmusen from Struer will come and look at it tomorrow (28-01-2015).
Kind regards and thanks
Pavia
It's sorted now :)
B&O came today and got it to work without the buzz.
Got a new one. They said that it might be a cable that had moved doing transport or otherwise.
They took the old tv back to the lab to be sure of there presumption.
I have also had problems with noise from my Avant 55 speakers, but it's repaired now.. The technicians had to change a long cable that was improperly mounted immediately behind the screen. The noise was noticable only when the screen was on, very annoying. It took a long time to figure out what the error was and basically the technicians had to change all the parts in the Avant.
Hi - I too have noticed a buzzing noise from my Avant, not from the speakers but from the panel behind the screen above the subwoofer. It's not very loud but noticeable, especially if low level volume in operation.
It also is only noisy when picture on screen.
Wasn't sure if this was normal/getting noisier but sounds similar to your issues. Is this where you were hearing the noise from too?
Will be contacting the dealer regardless as its bugging me!
Well, typically, as soon as raised concern with dealer, the noise is back to normal levels (i.e. very quiet and can only be heard if you stick your head behind the TV right up to the panel - and is still not particularly noticeable).
Will ask dealer to log it if it reoccurs, at least I know what I was hearing before was not within normal parameters as has rectified itself for now.
Fingers x'd.....
I am having the exact same problem with my Avant. The noise comes from the upper back of the tv (when the screen is on) as you describe and is noticeable within a distance of up to 8-10 m, if the sound of the tv is muted. Of course you have to listen carefully, but the noise is there. Is this acceptable? Did you get the problem fixed?
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael: (like the noise from BeoLit 15).
My Beolit 15 doesn't make any sound when not in use (power on) and I have a very good ear for that !
BeoGreg:My Beolit 15 doesn't make any sound when not in use (power on) and I have a very good ear for that !
