BM8000 distortion right channel
This post has 3 Replies | 0 Followers
Premiumverum
Netherlands
Posts 115
Premiumverum Posted: Thu, Jan 8 2015 10:57 AM
Hi all,
My beomaster 8000 has developed distortion in the right channel, independent of volume, it is present on all sources.
I suspected the offset so replaced the old original pots with new (precision) trimpots and did adjustments last week. This temporarily solved the problem. The BM was recapped 3 years ago.
Right channel offset drifts to 20-30mV every time after a few days, I have readjusted two times now.
I am thinking one or more bad input transistors (TR201, TR202), or maybe a maybe a bad solder joint on the right amp PCB.
Am I on the right track? Any measurements I can take to confirm suspicions?
Should replacement transistors be a matched pair?
I read this thread, don't think it is the same problem though because I have a drifting offset.
Would love to hear your thoughts on this.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Which Offset? The 0 mV at the output-stage or the idle current (18mV)?
Did you replace C205 and C211? Cold/Heat may infuence the setup.
Premiumverum
Netherlands
Posts 115
The DC offset at the output stage, it suddenly drifts away from around 0mV to 20-30mV after a few days when the symptoms appear.
C205 and C211 were replaced 3 years ago so not prime suspects but maybe one has gone bad early.
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Jan 8 2015 3:48 PM
Distorsion doesn't mean anything unless correlated.
Do you have crackling sounds?
Distorsion could be many things like bad solders or broken tracks after a careless re-cap, or bad power darlingtons.
Please tell us more!
Jacques
Page 1 of 1 (4 items) | RSS
