I just bought a complete set of White Beosystem 6500 units i.e. Beomaster, beogram, beogram CD and beocord from Germany.
So far I purchased a 1000W Step up/Step down transformer and a German 5 plug surge protector that I plug to the transformer. So far in testing things seem to work but there is almost tiny barely audible hum from the transformer (Not unbearable). Also I have not tried the Beogram yet.
My question is if it is possible to have these rewired for US Voltage and plugs? Is it cost prohibitive?
What is the downside of using the transformer especially from a power consumption?
hello, did you manage to answer this qustion? thanks
i managed to get an answer, all beosystem components can be re-soldered for 110v! :)
hello, did you manage to answer this question? thanks
thanks very much dave, i spoke to b&o and the also confirmed that a resoldering job would be possible on all components!
