I wonder if someone can help, i have a set of rl 60's and rl 45's and have connected to my 9300 with just the RL45 the sound is perfect but as soon as i add the RL60.2 the sound keeps turning itself down?
I am confused???
The 9300 has a protection circuit that turns the volume down when it thinks there is a too heavy load on the speaker outputs, but I believe it should be able to drive two pairs with no problems, unless you play really loud.
Does it do the same with the 60s alone? It could be a short circuit in the speaker cables or a faulty speaker.
--mika
Hi All sorted, i had a crossed cable on one of the speakers, user error!!
