What is the best way to connect a playmaker to BS9000 mk3? Is it through the masterlink or through the aux input? What cable do i need to buy?
Is there a way to do this all digital? I don't like the idea of connecting to the aux port.
Thanx,
I think there are two ways you could do this -
1) aux-out from the BS9000 to the input of the playmaker, and attach your speakers to the playmaker
2) speaker (powerlink rj45) out from playmaker into aux input of BS9000
only (2) allows the music sent to playmaker to go to other rooms if you have a masterlink system
option (1) means you won't have to power on the BS9000 to hear your playmaker,
Ryan: I think there are two ways you could do this - 1) aux-out from the BS9000 to the input of the playmaker, and attach your speakers to the playmaker 2) speaker (powerlink rj45) out from playmaker into aux input of BS9000 only (2) allows the music sent to playmaker to go to other rooms if you have a masterlink system option (1) means you won't have to power on the BS9000 to hear your playmaker,
And option 2 allows the use of the playmakers AUX-IN to be routed in other rooms via masterlink when no music is streamed to the playmaker.
Ralph-Marcus
Thanks guys!
