Beogram 8002 Rubber Feet
This post has 14 Replies | 0 Followers
dbxdx5
New Jersey
Posts 65
dbxdx5 Posted: Fri, Jan 16 2015 3:13 AM
Does anyone know the pitch of the screws that hold the rubber feet to the base? Thanks.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jan 16 2015 6:54 AM
If I remember correctly there are no screws. The feet are quite hard plastic and press-fit into holes in the bottom plate.
dbxdx5
New Jersey
Posts 65
dbxdx5 replied on Fri, Jan 16 2015 11:11 AM
Ah ok. Thanks Martin.
Jim Reeves
NPR, FL
Posts 5
dbxdx5
New Jersey
Posts 65
dbxdx5 replied on Fri, Jan 16 2015 2:30 PM
Good idea. I was actually asking about the original feet because I was thinking about replacing them with an adjustable type that allows for leveling. Right now, my 8002 has to rest on a glass shelf that is angled slightly, forcing me to shim the feet with coins to get the chassis and platter level. It works, but adjustable feet would be more convenient.
Jim Reeves
NPR, FL
Posts 5
I'd like adjustables for my 4002 too, but so far haven't found anything low-profile to suit the style of the turntable.
Søren Mexico
Mexico City
Posts 6,411
Jim Reeves:
Here are stick on feet in different sizes
dbxdx5
New Jersey
Posts 65
dbxdx5 replied on Tue, Jan 20 2015 3:20 AM
Thanks Soren.
I decided to experiment with putting four of these rubber anti-vibration pads under the four stock feet for increased isolation. Then I bought large black rubber washers of the same diameter as the bottom of pads to act as shims for leveling. It looks surprisingly good and seems to have improved the sound, making the bass a little tighter and improving instrument separation.
Søren Mexico
Mexico City
Posts 6,411
They look a little big to me 2.5" . will order some and try them.
dbxdx5
New Jersey
Posts 65
dbxdx5 replied on Tue, Jan 20 2015 6:04 PM
It's true that their size isn't in sync with the rest of the Jacob Jensen design aesthetic. For me, the simple flat black color and the shape that resembles purpose-built isolating turntable feet elevates them to inoffensive bordering on semi-decent. And did I mention they only cost me $4 at a thrift store? Big Smile
Søren Mexico
Mexico City
Posts 6,411
Amazon wants USD 6.00 inclusive shipping, we love pics Smile
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Jan 20 2015 6:20 PM
dbxdx5:
LaughingLaughingLaughing Now I want to see the result as well!
--mika
dbxdx5
New Jersey
Posts 65
dbxdx5 replied on Tue, Jan 20 2015 7:08 PM
Ok, photos will be taken/evidence gathered tonight!
dbxdx5
New Jersey
Posts 65
dbxdx5 replied on Fri, Jan 23 2015 11:59 AM
Technical difficulties uploading a pic. Stay tuned!
dbxdx5
New Jersey
Posts 65
dbxdx5 replied on Fri, Jan 23 2015 3:10 PM
Tough to get a good shot because of how close the shelf is to the floor (by necessity).
Page 1 of 1 (15 items) | RSS
