Beogram 4002 platter
This post has 5 Replies | 0 Followers
martanke
Posts 3
martanke Posted: Fri, Jan 16 2015 10:43 PM
Hello,
new member and first post. Recently picked up a Beogram 4002, type 5511 that needs some mechanical adjustments. So here's a silly question; when adjusting the platter, is it the metal base of the platter or the vinyls pads that should be flush with the surrounding metal plate?
/Martin
sonavor
Texas, United States
Posts 3,732
sonavor replied on Fri, Jan 16 2015 11:26 PM
The metal surface of the platter should be flush with the metal 4002 deck.  Before that however, you need to go through the service manual procedures to make sure the metal surface of the platter is the proper distance to the top of the detector arm (23mm).  After that, then work the suspension to make sure the platter and deck are flush.  It can take a long time getting the adjustments right.
-sonavor
martanke
Posts 3
martanke replied on Sat, Jan 17 2015 8:09 AM
Ok thanks!
sonavor
Posts 3,732
sonavor replied on Sat, Jan 17 2015 8:47 AM
This thread will show some information on the procedure.
I didn't notice you were a new member earlier...Welcome to Beoworld (better late than never) :)
martanke
Posts 3
martanke replied on Sat, Jan 17 2015 9:29 PM
Thank you :) This adjustment does take some time. Tricky with two different ways of adjusting the same parameter. I would think the turntable bearing is the technically important adjustment, and the spring mountings bit is more for aesthetics...
sonavor
Posts 3,732
sonavor replied on Sat, Jan 17 2015 10:42 PM
I would agree.
Page 1 of 1 (6 items) | RSS
