Excuse my ignorance , but is it possible to use an adapter to make a Beolit 12 effectively into a Beolit 15 ?
it would be good for those of us with the Beolit 12 and the Airplay has never worked and are too busy to send it back !
it would also be good of B&O to compensate those of us who bought before the price dropped by offering some kind of conversion to Blue Tooth as its a great speaker.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
We are thinking the same thing :)
I have one lying around just waiting to pop into the Beolit 12 when it arrives in a week or two.
My bluetooth adapter needs a 5v to work, and it will give a feed to anything that normally acn receive through USB. So I can´t see why it wouldt work.
It is this size, so it should be pretty nice :)
http://shop.leongtech.com/images/201106/goods_img/542_P_1309382965966.jpg
BeoLit12s have a three year warranty. If Airplay is failing on it, send it back and ask for a full refund. Then buy the Bluetooth 15 and save a few hundred pounds too. Rather than be upset about the price being dropped, just ask of a full refund. This is the only way that B&O will learn to make 100% performing reliable products.
I find it crazy that people are prepared to put up with expensively priced products that do not work properly.
What is a Beolit 15? I don't see it listed on the website
What is a Beolit 15. I don't see it listed on the B&O website
thorne: What is a Beolit 15. I don't see it listed on the B&O website
It is a rumour built on an assumption that the latest bluetooth (apx ?) will be brought to the Beolit 12 form factor and renamed as Beloit 15.
Like all assumptions it may satisfy that well know equation:
assume = ass+u+me
BeoNut since '75
Chris Townsend:Yes, you can buy aptX Bluetooth dongles on certain auction websites. The iPhone doesn't support aptX yet, but I'm sure it will so it's worth hunting for. Beovision 7-55 Mk2, Beovision 8-32, Avant RF 28, Beolab 8000, Beolit 12, Beocom 2, Beotime, H6, Form 2.
Interesting and i nearly had a conniption
OK i still have my 30 pin adapter BT dongle that i used for the BS8 that wasn't so successful, however, I just plugged it in to the BL12 via the 30 pin adapter to USB cable
It has power which is better than the BS8
Will keep you posted on the success
I haven't had much luck with this dongle, which is not limited to the BL12.
So far can't any device to see it however it does have power and the dongle lights are flashing.
I had the same thoughts and tried a:
Sandberg Universal Bluetooth Audio Link(https://www.cyberport.de/sandberg-universal-bluetooth-audio-link-auf-iphone-dock-konverter-adapter-2-0-4E99-00A_1273.html)
unfortunately without success...
Best regards
elephant:Great instructions. Should be put up on the beoworld wiki
....as was written in the FAQ's on the B&O website - 'Sound -> BeoLit 12'.
leosgonewild:Now I have a Beolit 12 with Bluetooth. It is duck-ugly (autocorrect intended).
Any verdict out what is working? Fair to say that the USB version don't work, but the line-in dongles do?
Anyone seen a less ugly one?
Hope anyone has tried this? Curious to hear from your experience.
