Anyone out there know if there are 3rd party (or even Panasonic) 3D shutter glasses that are compatible with the BV12? I tried the Xpand 3D (for use with Panasonic) which are identical to the ones provided with the BV12 and they failed to work. I also tried the Panasonic (TY-ER3D4MU)... again, no luck.
Perhaps the TV itself can be adjusted?
Thanks for any advice on this!
Hej Adammackillop,
The other day I have read something about the glasses somewhere in the forum. It was in a quit new topic around here. Maybe you have a quick look around.
Anyway, I welcome you here at the forum and wish you lots of fun.
BS9000, BC6, BC2, BL3, BL11, BL3500, BL2000, BeoTime, Beo EarSet2 3i, Beo, BEO DropStop, BEO Bottle Opener, BeoCom5 including Table Stand, ATV
Christmas Prize Draw 1st Winner 2010 - THANKS A LOT!!!
Struer Trip 2012 - THANKS A LOT!!!
Thanks so much Lars, much appreciated!
Thanks Vince- looks like B&O is the only choice for now... Oh well. I was looking to get some smaller ones for the kids, Panasonic makes some great ones.
There is a thread in the german forum stating that XPAND glasses are compatible with BV12. Have a look here.
The compatibility list of the XPAND glasses includes BV7 and BV4. So it very likely that BV12 works as well.
Maybe you have a problem with your glasses setup. I do not have these, so I cannot help you, sorry.
hfat
Hi hfat,
Thanks for this... I actually bought and tried those. I thought they would work for sure as they are exactly the same form as the ones included with the BV12. Unfortunately they don't sync. Bummer.
Thanks again,
Adam.
Did you try to manually select the IR protocol ?
This would mean that the BV12 has a different IR protocol from the one BV7/12 use.
No, didn't know you could change it... thanks hfat, I'll give it a shot now.
