Hi guys,
What is a good program to convert apple lossless files, and itunes 320 files to readable files by the Beosound 5?
Thanks!
Too long to list....
XLD on OSX and it is free
I wonder if you might want to hold off on converting those apple lossless files. Now that the Moment supports ALAC, hopefully the BeoSound 5 will see ALAC support in the near future. We've waited years for this. It might be worth waiting just a few months longer.
Well, you can always hope, that that will happen - I am not so sure about it.
Why not just convert the files now - and enjoy having a backup of them....just in case.
Yeah, I will not wait. :D
Want my music now.
I guess saving them to another location won't actually change the source files media type....?
Have my BS5 up and running now. Why didn't I get this earlier....?
Seems like this XLD can only do one file at a time?
No batch process?
Answering on my phone right now so cant check it out properly on t'net but dbpoweramp was always music file converter I trusted, although I've never needed it for a while - might be worth checking out!
Ban boring signatures!
Puncher: Answering on my phone right now so cant check it out properly on t'net but dbpoweramp was always music file converter I trusted, although I've never needed it for a while - might be worth checking out!
Will it handle cover art? No one I've tried sofar manages to get the cover art....
Seems to be a big problem getting cover art to FLAC? From M4A???
Any suggestions?
DBpoweramp music converter!
EZ CD Audio Converter (www.poikosoft.com)
Will these get the coverart onboard?
dbpoweramp does
koning: dbpoweramp does
OK, thanks. Seems to be a windows application though.
bayerische: koning: dbpoweramp does OK, thanks. Seems to be a windows application though.
At least something that a Win-OS can do better, than a Mac-OS
You could borrow a Win laptop for a weekend and do the convertion there - instead of
chasing the 'right' Mac appplication (which won't be easy to find).
Millemissen: bayerische: koning: dbpoweramp does OK, thanks. Seems to be a windows application though. At least something that a Win-OS can do better, than a Mac-OS You could borrow a Win laptop for a weekend and do the convertion there - instead of chasing the 'right' Mac appplication (which won't be easy to find). MM
I do have windows on both my MBA on parallels, and as a stand alone on a HD on my "Hackintosh", however, Windows won't find drives formatted to OS X extended journaled.
I have 160Gb or so music files, that will be roughly twice the size I think. Not too great to shuffle them with a 8gb USB stick!
Max converter does this beautifully for Mac!
bayerische:Have my BS5 up and running now. Why didn't I get this earlier....?
I'm not sure, but I remember plenty of people saying in the past how they will never get such a pointless product because it doesn't have X and doesn't do Y
Pictures are required!
--mika
tournedos: bayerische:Have my BS5 up and running now. Why didn't I get this earlier....? I'm not sure, but I remember plenty of people saying in the past how they will never get such a pointless product because it doesn't have X and doesn't do Y Pictures are required!
I was one of them!
Why did you changed your mind ?
Are you happy with the BeoSound 5 now ?
Steph: Why did you changed your mind ? Are you happy with the BeoSound 5 now ?
I love the Radio feature of it, living in a small town with a very *shitty* ADSL, going to change it in spring once the contract is up! (Thanks for nothing Sonera) I really enjoy the fact that the Bombaster 5 buffers the radio properly, so a 20sec or so internet timeout isn't meaning radio-hiccups!
But it's been in my house for about 20 hours, so hard to say if I'm happy with it yet. Bit of a pain to convert & transfer all the FLAC files. Must remember to make a backup of them too!
The promised pics:
Thanks !
Great pictures !
Agree with you, Nradio is a great feature. MOTS too. And i really love the design, the wheel,... The whole user experience.
BeoNut since '75
elephant:@bayerisch Did you hide the cables and base unit inside the wooden box ? Did you make use of the crack on the lid ? Or drill hole(s) ?
This is a temporary solution.
Yes the Beomaster is inside the middle box, there's three of them.
Didn't drill in them, since this is a temporary solution, and we want the boxes whole.
