Yesterday evening I was playing with the BeoRemote App on my iphone.
I was surprised to see that it didn't find the V1. Any thoughts what went wrong? I assumed that the iphone app had that same functionality as the iPad app, which works as expected.
Any suggestions?
ps. the Polymote app can find my V1 so the problem is not in the wifi/LAN set-up
I've noticed that starting the BV11 from cold (i.e., using the app and not the Beo4), it takes a good 3-4 times of starting the app on either iPhone or iPad and then force quitting the app (double click home button and swipe up on the app) before it actually finds my BV11.
benjnz:I've noticed that starting the BV11 from cold (i.e., using the app and not the Beo4), it takes a good 3-4 times of starting the app on either iPhone or iPad and then force quitting the app (double click home button and swipe up on the app) before it actually finds my BV11.
Yup have got the quick time start now set for 16:30-1900 daily, seems to help, and I had Eco off. ;-)
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
It often (but not always) takes so long, that I in the meantime have had time to fetch my Beo4
Hi all,
I don't know why the 2.0 version has got problems in finding the TV's in some situations.But let me explain the different powersaving / startup modes.
Quick start timer: if enabled the TV stays ON all the time. It is fully accessible via network and the app / Beo4 only needs to send a "SOURCE" command to fire up the screen.
Wake on (W)Lan:If quick start timer is disabled and WOL is enabled the TV will shutdown if STANDBY was pressed. The only part that will still be active is the network controller. It will listen for the "magic WOL package". The remote app will send out this specific package and the TV will start booting immediately. It will take nearly the same time as if you activate it via e.g. the Beo4. If the app detects that the TV is fully accessible via network it asks you for which source should be activated.
Quick start and WOL disabledIn this mode the TV can only be activated via incoming IR commands. The TV will consume least power in standby.
BR,BeoMotion.
Thanks for this hint. It helped on my side.
BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
