beocenter 2500 multiple aux sources
This post has 1 Reply | 0 Followers
McRib
Posts 36
McRib Posted: Sun, May 27 2012 3:47 AM
On a Beocenter 2500: any way to record from an external source to an external deck (like an sacd player to a beocord 6500). there is only one aux jack so i'm guessing no--?
AT
Budapest, Magyarország
Posts 235
AT replied on Mon, May 28 2012 5:51 PM
I'm not sure if I understand well Your question, but why You want to install anything between two external sources? Connect them directly and record from one to the other. However, the BC2500 have a Line In (Aux) connection for input, and You can use the masterling connectors with a five PIN DIN for AUX temporary. In this case one of Your speaker will not work (if You use BL2500 for it), but You can do what You want to do.
Page 1 of 1 (2 items) | RSS
