Digital audio connection from Mac mini to Beovidion 7-32 mk II
This post has 7 Replies | 2 Followers
PhilLondon
London
Posts 3,637
PhilLondon Posted: Sun, May 27 2012 12:38 PM
I would like to connect my Mac mini to my Bv7-32 using a digital audio connection rather than an analog connection.
The Mac mini is sp/dif , the TV uses Coax RCA. I do not know what kind of adapters I need.
Any help appreciated.
Beoworld app with direct photo upload and emoticons.
Michael
Sweden
Posts 2,578
Michael replied on Sun, May 27 2012 3:04 PM
PhilLondon:
As far as I know the BV7 has a little unusual digital input. It can not play PCM-audio, just Dolby. If it doesnt detect a Dolby-signal it will try to take analog sound first (not the spdif-input).
If you really want to send digital audio you have to get an optical to coaxial converter but I think you also have to send analog audio. Since this is how the digital input works I don't think you will have a lot of use for it unfortunately.
DoubleU
Posts 562
DoubleU replied on Mon, May 28 2012 8:48 AM
It can play digital PCM-audio, unless the software of your DSM-module is upgraded to 3.x
You can see what software it has now in your service menu. Probably it's 2.5
Michael
Sweden
Posts 2,578
Michael replied on Mon, May 28 2012 9:28 AM
DoubleU:
I did not know this but do you mean that older software can play PCM but the newer models can't?
Sounds strange
DoubleU
Posts 562
DoubleU replied on Mon, May 28 2012 10:46 AM
Why do you think that 3.x is older than 2.5 ?
DrDimitris
Greece
Posts 699
DrDimitris replied on Mon, May 28 2012 10:57 AM
I think is is not only software related. You will need a chip also. Read HERE
"For the sound you need DSM SW version 3.01 (part no 8344439 ) . I did it on my BV7 now it works perfectly. The chip is quite cheap (40 Euros) but the BO technicien need to come and open your TV.
SW must be above 7.84 you can find it in customer service menu. MENU then OPTION (only highly don't go in) then RED arrow with BEO4 then GO"
Dimitris-
Michael
Sweden
Posts 2,578
Michael replied on Mon, May 28 2012 12:26 PM
DoubleU:
I read it as you ment that it could play PCM if it was not upgraded to 3.x but I guess you meant that it plays PCM from 3.x and up?
PhilLondon
London
Posts 3,637
Thanks,
I am glad I asked as I was about to buy a converter. My TV's software is too low.
Hopefully I am not loosing too much quality buy using an analogue connection.
Page 1 of 1 (8 items) | RSS
