I wonder if anyone had a similar problem with BV11. I had a wired connection since purchasing, so I never used Wifi.
Recently I relocated the TV to a location with no wired Internet, so it was the first time I tried to set wifi up on it. However I get "Connecting..." for a few minutes then it goes "Disconnected". Tried different wifi router and it's still having the same problem. Can anyone help?
Ah, you know... A little B&O here, a little there
Thanks BeoMegaMan. Tried the factory reset, but still no luck. I guess I'll have to give B&O a call then.
