Hi everyone,
Am considering changing tv. Unfortunately current finances not allowing me to consider a new or second hand Beovision 10 or 11 so am looking at usual suspects (Samsung, Sony, LG etc). Is it still possible to connect either of the above speakers to a non B&O TV? Does anyone have experience with this and which, if any, are the better of the two? This way at least I can get B&O sound and using a linntronic get control with a Beo4.
Thanks,
Graeme
Don't forget that you will also need either the table stand or wall bracket. The BeoLab 7 has two base ports underneath the cabinet so placing the speaker directly on a shelf will greatly impair sound quality.
Opman
I think, from a normal TV, you will need something like this cable from Sounds Heavenly to go to the Beolab 7.1
http://www.soundsheavenly.co.uk/bando-ipodlab2.htm
Thanks everyone. I have seen the 7-1 going for reasonable prices, and thinking the sound will be as good if not better than any soundbar from Samsung etc. I take the point about the stand too, and actually think they look good on the stand anyway.
thanks again,
G.
They are excellent as a link-speaker in a ML-setup.
