Beovision 7-40 MK I or Beovision 8-40 from 2011?
Johan
Sweden
Posts 10
Johan Posted: Fri, Jan 30 2015 9:51 AM
Hi everyone!
I have a delicate problem. My current main room TV is a BV 7-40 mk I with a Beolab 7.2 connected to BL 8000 and BL 4000. A week ago I came across a BV 8-40 for a vey good price. Which one should I keep?
I think the 8 has better picture quality (it is Full HD as opposed to the 7). Menus are nicer looking at the 8 and it has built in DVb-T. I use a STB for the 7. Isn't the 7 supposed to be better?!
so in short: which one would you keep?
markiedee
UK
Posts 425
markiedee replied on Fri, Jan 30 2015 11:02 AM
I'm also tempted to buy a bv8-40 i much prefer it to the v1 design wise and picture wise. Although i would Prefer a much bigger tv i have always liked the picture quality of the bv8-40.
what mk is the one your looking at?
Beoplay A2
Chris Townsend
Qatar
Posts 3,531
The 8-40 will have a much better picture, and sound wise is about the nearest thing to the original Avant. And that's a good thing.
Plus it had hdmi slots, making the choice of compatible sources much bigger.
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Fri, Jan 30 2015 12:03 PM
My choice, the 8-40 over the Mk1 7-40. Alternatively you could update your 7-40 panel to a Mk3 and use your existing stand and speaker..
x:________________________
Millemissen
Flensborg, Denmark
Posts 14,680
Definitely the 8-40!
Page 1 of 1 (5 items) | RSS
