Beocord 1900 Cassette Deck cable question
This post has 2 Replies | 2 Followers
photoecology
Posts 1
photoecology Posted: Sat, Jan 31 2015 3:27 PM
Hi there. This is my first BEOWORLD post. I am trying to work out what cable I need to connect the late 70s/early 80s BeoCord 1900 tape deck to my Beomaster 2400-2 Tuner/Amp. They both have DIN connections but not sure which cable I need.
Can anyone suggest a supplier who would post to Australia. Thanks!
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Jan 31 2015 3:50 PM
You just need a 5 pin DIN cable with male plugs each end.
Sounds Heavenly have a super duper one here and deliver to Australia for free! http://soundsheavenly.com/naim/120--5pd-5pd-.html?search_query=5+pin+din&results=66
I confess to thinking you really don't need such a good one and am staggered that you can't find one in Australia!
Maplins do one in the UK http://www.maplin.co.uk/p/5-pin-din-cable-audio-and-midi-5m-l57ba
Look for a 5 pin MIDI cable as this is the same thing! Maybe this? http://www.troymusic.com.au/accessories/cables/midi-cables/2m-midi-cable-with-metal-plugs/
Peter
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi photoecology,
Welcome to the forum!  Also, thanks for your email, I've just sent you a reply Smile
Hi Peter,
Many thanks for your kind recommendation, I'm happy to post this cable to anywhere in the world at no extra cost.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (3 items) | RSS
