Hi everyone.
I have a Beocom 6000 for 7 years and it works wonderfully. It is the version with the separate PSTN base.
3 years ago I bought a Beocom 2 and paired it with the PSTN base. No problem at all. Worked wonderfully until last week.
Last week the Beocom 2 unregistered from the base and now I can't register it back.
I press the buton behind the PSTN base, the Beocom 6000 registers at once but the Beocom 2 keeps searching for base without success.
What is wrong? Is there anything I can do?
Thanks.
Regards,
Mike
Hmmmm.... I'll try that.
Thanks, leosgonewild.
That did the trick. Never would have guessed that there is a particular order to register the handsets
