Dear all
I am wondering how I can update the PUC list of my Beovision 7-32? It is a model with DV-I socket and HD.
Can someone help me?
Thank you and have a nice evening.
Noah
Hi Noah
To update the PUC list you need access to the B&O Service Tool. This is not available to the general public. You will need to arrange this through your local dealer or service centre.
Its not a big job and only takes few minutes. I guess depends on how well in you are with your dealer as to how much they will charge you to update the PUC.
Its worth thinking about which other products you may want in the future and having those added at the same time. Wouldn't harm to have some generic boxes just in case.
Opman
A B&O serviceman needs to come to your home and connect to your tv in order to update them.
If you choose to do this, make sure you get the software and audio upgrade at the same time.
