Beoremote One and BV-11
sq2002
Posts 58
sq2002 Posted: Fri, Feb 6 2015 7:38 PM
Just recieved the new silk version. I have some questions, I hope you guys can help me Smile
What is exact the difference when setting in the BV-11 the remote from Beo4 to Beoremote One ?
Light function : can it be programmed with one of the 3 My-buttons ?
Is it possible to activate the Text and Guide button ?
Thanks !
KMA
Posts 621
KMA replied on Fri, Feb 6 2015 8:01 PM
The 3 My Buttons can save a "snapshot" of BV11 (source, stand position, volume, picture and audio mode) when BeoRemote One is selected from BV11's options.
"Guide" and "Text" will also work (Text works with broadcasts that include Text TV, so not on all channels on my BV11, but on most).
As for lights, maybe somebody else has the answer for this?
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sat, Feb 7 2015 2:29 PM
Light : you can set it on one of the three mybuttons or have it under "list".
So yes you get access to light control.
sq2002
Posts 58
sq2002 replied on Sun, Feb 8 2015 7:25 PM
I did manage to get LIGHT in My button, but can you also store for example LIGHT 2 as a setting ?
And I have UPC Horizon, but Text and Guide buttons don't work... ?
KMA
Posts 621
KMA replied on Sun, Feb 8 2015 10:50 PM
sq2002:
Are you using an external set-top-box for TV, or BV11's internal tuner? Both Text and Guide work at least when using the internal tuner (dual cable tuner in my case).
KMA
sq2002
Posts 58
sq2002 replied on Sun, Feb 15 2015 4:17 PM
UPC Horizon is an external box, but all other functions work only these 2 not
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Feb 15 2015 5:08 PM
If some buttons don't work together with PUC controlled external devices, this only depends on the programmed PUC tables by B&O.
Page 1 of 1 (7 items) | RSS
