NL/ML Converter update problem
BeoMedia
Posts 100
BeoMedia Posted: Sat, Feb 7 2015 2:11 PM
Hello,
I have a BV11 connected to a BS3000 via NL/ML Converter. The converter and BS3000 has not been connected for a while as recently moved house.
My problem is that on my new network I cannot update the SW. I only get as far as 2% and then I get the below error message: Any idea what can be wrong? There seems to be access to the Internet as it an see the new version and the date and time of the setup page is correct.
Help much appreciated!
Software status
Current version1.3.0.0[release notes]
Available version1.4.0.18322[release notes]
Update statusNetwork error occurred. The file may not exist in BeoPortal
Chris
Ostend-BE
Posts 1,170
Chris replied on Sat, Feb 7 2015 2:31 PM
You can access the web page?
Ist the converter connected to your network by DHCP or fixed.
I had the same problem once with my fixed adress, It was a wrong DNS adress.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
BeoMedia
Posts 100
Yes I can access the web interface. I have connected via DHCP according to the settings displayed under the network tab (though I am not really sure if DHCP is what I need).
I have a router and a switch between my modem and the NL/ML Converter so likely some wrong settings in the router but I don't know where to start.
Chris
Ostend-BE
Posts 1,170
Chris replied on Sat, Feb 7 2015 2:56 PM
The converter has no fixed adress, so its installed DHCP, you say. If you connected it directly to the switch, check your settings of router. Guess you have to make an adjustment in the router, something is blocking it. Or it gets no IP from the router.
BeoMedia
Posts 100
For the purpose of updating the NL/ML I have now connected it directly to the modem which also has wifi. I now managed to download 100% and install 100% but in never reboots and in the log it writes "The product is scheduling a lazy reboot..."
Nothing happens, it remains on the old sw version, then checks for a new version which it downloads 100% and trying to install it writes the following in the log: "SoftwareUpdate threw a SWUpdater::ChecksumFailureException: Checksum verification failed"
All very odd - do you have any idea please?
Chris
Ostend-BE
Posts 1,170
Chris replied on Sat, Feb 7 2015 3:32 PM
Maybe doing a reset helps, it looks stuck somewhere.
mjmedlo
Posts 922
mjmedlo replied on Sat, Feb 7 2015 10:04 PM
Try using the b&o set up app if you have a smart phone.
Mine has doe this before too.
Also, unplug from the mains for an hour or so so it can forget everything.
BeoMedia
Posts 100
BeoMedia replied on Fri, Feb 13 2015 7:19 AM
Hello all,
Thank you for your help. Somehow the unit just updated itself while connected the same way to the network. For the reference to this forum and other members that may incur the same: what (I think) helped me was to reset the network settings and unplug the unit for a couple of times (though once for a longer period should suffice) and also ensure the network was restarted to be on the safe side. When I then tried to login to the unit it took some time and when I finally got it it had updated (was set to automatic updates).
Thanks for your hep!
Chris
Ostend-BE
Posts 1,170
Chris replied on Fri, Feb 13 2015 4:47 PM
DHCP is a good option for easy home networking. But sometimes DHCP gives a new IP after every 8 days by default, could be one of the reasons why it went off. Using a static gives you the only advantage of a fixed address and some more security in your network, more control. But it does not goes faster as sometimes people think.
Chris
Page 1 of 1 (9 items) | RSS
