Beogram RX-2
This post has 21 Replies | 0 Followers
DaveD
Posts 8
DaveD Posted: Sun, Feb 8 2015 12:05 AM
Got my RX-2 out of storage hooked it up, and it doesn't play, if I cue the arm to the middle of the record it just seems limp and goes to the beginning of record, the anti skating is set correctly, any other ideas?
Thanks Dave
Søren Mexico
Mexico City
Posts 6,411
Cartridge needle cover down
DaveD
Posts 8
DaveD replied on Sun, Feb 8 2015 12:41 AM
No, I did check that.
Søren Mexico
Mexico City
Posts 6,411
Bad needle, tracking force
DaveD
Posts 8
DaveD replied on Sun, Feb 8 2015 3:22 AM
So a new cartridge will solve my problem?
is there a web site that is best to order B&O cartridge s from?
Søren Mexico
Mexico City
Posts 6,411
Did you check the cartridge, needle there, needle riding in the track, or is the cartridge housing touching the record.
DaveD
Posts 8
DaveD replied on Sun, Feb 8 2015 4:18 AM
There is a needle there
Søren Mexico
Mexico City
Posts 6,411
DaveD:
Thats a good thing, is this needle touching the record when playing, or is the cartridge housing touching the record.
DaveD
Posts 8
DaveD replied on Sun, Feb 8 2015 12:08 PM
The needle is touching, when I touch the play button the arm moves over the record and drops down [needle on record] but then does not go anywhere, although I do hear some pops thru the speakers, Thank so much for your help.
DaveD
Posts 8
DaveD replied on Mon, Feb 9 2015 1:52 PM
Well I seem to have gotten the turntable to work, it was the anti skating on bottom,  The high end of the music is gone - Im guessing I need a new cartridge, this one is 20 years old. So now my question is where is best place to buy a Bang & Olufsen cartridge mmc 5?
Søren Mexico
Mexico City
Posts 6,411
Did you adjust the tracking force ? first adjust to "0" then set the force to 1.5. You can get your MMC5 repaired here
DaveD
Posts 8
DaveD replied on Tue, Feb 10 2015 10:33 PM
I have a chance to purchase a B&O 1700 and a B&O 2400, both owners claim cartridges are good, both are in good shape, both are listed at $125. I've searched the web trying to find the differences without luck.  Which turntable is a better deal at that price
DaveD
Posts 8
DaveD replied on Tue, Feb 10 2015 11:04 PM
I should also mention $199 for a new cartridge for my RX-2 turntable vs $125 for each of those other B&O turntables.
Søren Mexico
Mexico City
Posts 6,411
The BG 2400 should have a preamp build in (check in the product list), the BG 1700 not. The BG 1700 has normally a MMC 20 S cartridge, the BG 2400 normally has a MMC 20 EN, BG 2400 is known to have problem with the push button/swithches.
Søren Mexico
Mexico City
Posts 6,411
DaveD:
Repair of your MMC cartridge is cheaper, and all cartridges this age are prone to suspension giving up, if possible check the decks before buying.
Cleviebaby
Exeter, United Kingdom
Posts 672
One other advantage of a repair  by Axel is it would allow you to upgrade to a higher specification MMC cartridge  -  an MMC4 or even an MMC2.
Cleve
Steffen
Denmark
Posts 1,408
Steffen replied on Wed, Feb 11 2015 1:15 PM
Søren Mexico:
Sorry, but I don't think the BG 2400 has preamp build in, as the Beomaster 2400 has RIAA.
Søren Mexico
Mexico City
Posts 6,411
Steffen:
I was wondering too, but according to the product list it has
BeoGram 2400 Record Deck Product Specifications
Types: 5722, USA 5716
Speeds 33 - 45 rpm
Speeds control range > +/- 3 %
Wow and flutter < 0.06 %
Rumble weighted > 65 dB
Rumble, unweighted > 45 dB
Drive system Flat Belt
Motor Servo controlled DC
Power supply 220 (110) V
Power consumption 8 W
Dimensions W x H x D 44 x 8.5 x 37cm
Weight 6.5 kg
Stylus Elliptical diamond
Pick-up MMC 20 EN
Recommended tracking force 12 mN / 1.2 g
Frequency range 20 - 20,000 Hz +/- 2 dB
Stylus Elliptical naked diamond
RIAA amplifier: built-in
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Feb 12 2015 12:46 AM
Hmm - that must be something special for the US market, then... I have a Beomaster 2400-2 with RIAA - and a Beogram 2402 with no RIAA.
(Edit) And if you look at the specifications of the BG 2200, there's no RIAA. And it's mentioned that:
Beogram 2200/2400 were identical except that, when coupled to the Beomaster 2400, Beogram 2400 could also be operated by remote control.
So I guess the RIAA in the 2400 is simply a mistake by the writer.
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Feb 12 2015 12:57 AM
And the Beomasters did have RIAA in both incarnations...
BeoMaster 2400/2400-2 Tuner/Amplifier Product Specifications
Types:
2901 (1976 - Dec 1979)
US 2902 (1976 - Dec 1979)
2905 (1979 - June 1983)
J 2907 (1979 - Dec 1982)
CDN 2908 (1979 - Oct 1983)
Frequency response: 30 W per channel at 4 ohms
Minimum continuous RMS power: 25 W per channel at 8 ohms
Speaker impedance: minimum 4 ohms
Maximum total harmonic distortion: < 0.2%
Intermodulation: < 0.15%
FM tuner range 87.5 - 108 MHz
Power consumption: 25 - 185 W
Dimensions H x W x D: 6.5 x 61.5 x 24.7cm
Weight: 7.6 kg
RIAA: built-in
Features: cordless remote control, sensi-touch operation
Connections: headphones jack
Speakers: 2 set
Tape: DIN
Phono: DIN
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Feb 12 2015 7:44 AM
Søren Mexico:
Steffen:
Speeds 33 - 45 rpm
Weight 6.5 kg
Pick-up MMC 20 EN
My BG2400 does not have an inbuilt RIAA.  I have to use an external one depending on which amp I connect it to.  Confusing eh!
Dave.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Feb 12 2015 8:42 AM
Unfortunately, our product guide tends to misinform a bit when it comes to the older audio stuff, lacking at best.
I am not sure about the US model Beogram 2400 but I never saw a RIAA in any of the sloping front 2200/2400/2202/2402 and
I don't recall seeing any info about a RIAA option for these models either.
Page 1 of 1 (22 items) | RSS
