I have a very simple question. I Just would like to know, how can I find out the age of my Beosound 9000 ? Also it selects a disc but does not play the disc will not spin any ideas ?
Yep. The serial will give you it's age. And most probably, the laser died and needs to be repalced. Sorry.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
First three numbers of serial number are 164 ?
Thanks, first three numbers of serial are 164 where do I find out ? And someone told me it was a mk 1 and said you can't get the parts for them any more do you know if that's right ? Thanks again
Repairable then..
Type 2562 : Mk2
Type 2572 : Mk3
50/50 laser at that age. Have you cleaned it?
Lee
Type 2572 ? And yes I tryed cleaning it with a cotton bud
So which mk would that make, iv been told you can't get spares for a mk 1 ?
