Hi!
Need to replace laser diode on Beosound Ouverture,type 2631 , ser.no.14853486.
Cd drive VAU 1253/00 , laser diode 00515133 TDA1302T , board CDM 12.82 modi 00/37
Where to buy replacement,or any alternative?
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
I normally use this one.. but only on the straight and vertical mounted lasers, not the arch type in the earliest models..
http://www.ebay.de/itm/171650561552?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
/Weebyx
Thanks Weebyx , are you sure this one works with Ouverture?
Yes, I have changed one in an ouverture with this one, works perfect..
Just make sure it is this lasertype :
http://www.beoshop.se/public/img/user/2173911.jpg
And not this one:
http://members.modernvespa.net/zagato/uploads/beodesign_iphone_dock_132.jpg
Only the vertical lasers can be replaced as far as I know, but the arched lasers normaly is more robust, and does not cause problems.
Yep, works.
Hello!
I whant repair my VAU 1253 an Need our Help:
First The CD dont start.
No repalce the Laser Diode (unit). I thake This Part from China: http://cgi.ebay.at/ws/eBayISAPI.dll?ViewItemVersion&item=321839475116&view=all&tid=1694257111011
Now the CD start, but dont Play Musik!
Please can yuo help me, whats the Problem?
Wrong Laser od bad Quality?
sorry for my bad english:-)
greetings Bernd from Austria
Please can you help me?
i replace the Laser Diode from my VAU 1253/00
I take this Part from China. http://cgi.ebay.at/ws/eBayISAPI.dll?ViewItemVersion&item=321839475116&view=all&tid=1694257111011
Nox, the CD start for 30 Seconds but it Play no Music.
Have i take the wrong Part?
Is the Quality bad?
Hi Siem! Cannot access yours link on ebay to check,
Two years back i bought this from chinese seller (Laserlands) on ebay,cca 17 $:
NEW Original Philips VAM1204 CDM12.4/05 Laser Head Pickup Lens with mechanism
Still working ok with my Ouverture
