hi everyone,
a bit 'old skool' here. I have an old iMac G4 with OSX 10.4.11 connected to a BC9300, mainly for Spotify but sometimes for my iTunes as well. I don't know anything much about Beoport other than it will allow control of iTunes via Beo4. How does this actually work? Is it still available- or even is it worth the bother as my current system works very well and I appreciate the Mac is now very old and basically obsolete. To me it is just a fancy juke box for Spotify and iTunes, but Apple and B&O do seem to sit well together.
Some info and advice would be much appreciated.
Thanks,
Graeme.
BeoNut since '75
Beoport needs special software and - because of the BC9300 - an external IR-Eye to be controlled with a Beo 4. I can understand you old school love for the G4: The quicksilver versions where such beautiful designed machines! :)
Software:- BM Link: http://www.odlund.se/bmlink/
- Linkplayer: http://www.conversation-it.co.uk/LinkPlayer/Linkplayer.html
The software accesses your iTunes library and you can control Play/Pause/Skip forward/Skip backwards with the Beo 4. I don't know if the Beoport requires a Masterlink device to work properly. I used it with a BS3000 with Masterlink and it worked fine for standard control but surely not for browsing your library.
