HTTP Button
This post has 35 Replies | 3 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sat, Feb 14 2015 3:03 PM
Hello Automation lovers
I have a Biolock on my front door that has IP control (limited)
If i open a web browser / favorite of the below i can remotly unlock my front door for a number of seconds.
http://192.192.1921.192/dyn?login=&username=secret&password=secret2&button=Open+Door
Can i assign a link to a button that could appear in the app?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Sat, Feb 14 2015 3:38 PM
You'll have to have the custom strings protocol then tell he blgw the ip.
But it should work no problem I would think.
Seanie_230
UK
Posts 2,278
Thank you
i assume I add a custom sting system and then the IP of the device with port.
do I add an event ?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Sat, Feb 14 2015 9:05 PM
Seanie_230:
Thank you
do I add an event ?
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
The event will be the trigger or button you create as a virtual button. Called 'unlock'. Or whatever you decide.
The command will be the 'custom strings'
Then write the command line for the unlock.
Seanie_230
UK
Posts 2,278
Hi there
thank you for the help
i have tried to create a button as the first step but don't have a good enough understanding yet
can anyone give me an idiot step by step to get started on how to create the button and then add a comment to it.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Sun, Feb 15 2015 11:40 PM
Under resources go to virtual buttons.
Then create your button
The under systems create this ip lock as a custom string.
Then under macro create a news to with this new virtual button triggering the custom string unlock.
👍. Good luck.
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sun, Feb 22 2015 12:31 PM
mjmedlo:
👍. Good luck.
Hi there
i created a virtual button under resources I created a button with LED
i went to systems and added a custom string called unlock it needs some info can anyone help?
it asks for end of line, host and port any thoughts ? Is end of line the URL to open the door or does that go in host?
Cheers all
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
mjmedlo:
👍. Good luck.
Hi thrre
I have followed your instructions, i have created a virtual button under resources called Unlock this appears on every zone under scenes as Unlock.
I went to system and added a custom string called Unlock door with the below settings
where do i add the URL as i tried to put this in host but it does not allow it and changes the icon to red.
End of line says illegal character
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Any if you lovely people want to help me with a team viewer session to get the door button working?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Sun, Feb 22 2015 7:42 PM
Seanie_230:
Will you snap a photo of the door protocol and your programming page?
PhilLondon
London
Posts 3,637
Try:
GET /dyn?login=&username=secret&password=secret2&button=Open+Door HTTP/1.1\0D\0A
GET /dyn?login=&username=secret&password=secret2&button=Open+Door HTTP/1.1\0D\0AHost: www.example.com\0D\0A
Beoworld app with direct photo upload and emoticons.
Seanie_230
UK
Posts 2,278
Hi there
where do those commands get placed?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
PhilLondon
London
Posts 3,637
In resources > Custom String > Address
Then you call that resource in a macro.
Seanie_230
UK
Posts 2,278
Hi Phil
I have tried that with both of the samples you gave, I changed the username and password to match also with the host on the second one being the IP address.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
2nd One
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
3rd Macro page
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
PhilLondon
London
Posts 3,637
Looks OK to me...
Seanie_230
UK
Posts 2,278
PhilLondon:
Looks OK to me...
When i hit fire macro it does not open the door.
If i use the original link from a browser it works.
I am sure i am probably missing something.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
I just used capture to ensure i have the event correct and this added press and release.
It must be something to do with my custom string that sends the command to the door relay.
Frustrating but fun :)
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
New macro with captured events
Problem seems to be the custom string
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Sun, Feb 22 2015 9:38 PM
So you have the door connected?
Try using the monitor to see what command the doors sends/receives
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sun, Feb 22 2015 10:05 PM
hi there
yeah the door is conencted to ethernet and if i use IE the door unlocks using the URL
below is the monitor
does this look right:
Monitoring
15-02-22 22:03:45 Integration protocol message Integration Protocol: stateful virtual button 0x0
15-02-22 22:03:45 Event fired global/Global/BUTTON/Unlock/PRESS
15-02-22 22:03:45 Macro fired global/Global/MACRO/Unlock front door
15-02-22 22:03:45 Integration protocol message Integration Protocol: stateful virtual button 0x0 0x3
15-02-22 22:03:45 Event fired global/Global/BUTTON/Unlock/RELEASE
15-02-22 22:03:47 Command selector executed global/Global/_CUSTOM/Unloc/_OUTPUT
15-02-22 22:03:47 Command executed global/Global/_CUSTOM/Unloc/_OUTPUT
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Thu, Feb 26 2015 10:45 PM
Hi all
I received some feedback from Bang & Olufsen via my dealer today.
The BLGW is not able to send the url as the protocol does not support sending the url. It either wraps the the message is rs232 or tcp packet.
I suppose I will have to give up on this one
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
PhilLondon
London
Posts 3,637
PhilLondon replied on Thu, Feb 26 2015 10:57 PM
That's what I found as well, but that's a bit more complex than that...
HTTP requests are TCP packets... so the BLGW can perfectly send requests (which should be executed, I made it happen with the Hue Bridge), however the HTTP server closes the connection just after executing the request.
The BLGW detects that the connection is broken and tries to re-establish the connection, without sending anything... the HTTP server being no HTTP request coming closes the connection... etc, etc...
I do not know if the MLGW has the same "auto connect" feature... But the only thing that B&O need to do is a setting to disable the auto-reconnection and then it'd be fine.
p.
beojeff
USA
Posts 2,012
beojeff replied on Fri, Feb 27 2015 10:05 PM
Phil,
I have not had the problems of the unit trying to re-establishing connection on the MLGW. Is it possible that for the "type" of command you are using in the custom string that you are using the option "both ways" instead of "output"? I am using "output" for my custom strings and it does not try to re-establish a connection because it is not looking for an incoming signal. Also keep in mind that the custom string uses the old Telnet language and that you must enter the "content length" of the command.
Jeff
PhilLondon
London
Posts 3,637
PhilLondon replied on Fri, Feb 27 2015 10:40 PM
I think it's indeed a difference between the BLGW and MLGW.
Telnet isn't the issue. Only character 0xff is send in a special way, the rest it transmitted as is.
In my case the commands actually work, it's just that the BLGW goes into a loop and becomes really slow.
beojeff
USA
Posts 2,012
beojeff replied on Fri, Feb 27 2015 11:13 PM
PhilLondon:
Does the BLGW offer you the 3 options for the "type" of command that the MLGW does?:
1. Both ways
2. Input (match)
3. Output (command)
PhilLondon
London
Posts 3,637
PhilLondon replied on Fri, Feb 27 2015 11:33 PM
beojeff:
Yes.
Here's what's in the BLGW online help, on the Custom String page. Do you have that on the MLGW?
TCP connection maintenance
Read this section if you experience periodic TCP reconnections.
In order to rapidly detect broken TCP connections, BLGW uses the standard TCP Keepalive probes mechanism: when a TCP connection is idle, probe packets are sent periodically over the connection and an acknowledge is expected. The probe is an empty TCP packet with the request for acknowledge flag set.
This method for detecting active connections is specified in RFC-1122 section 4.2.3.6.
There are products with non-compliant TCP implementations which do not respond to these acknowledge requests. In such cases, HAGW will detect a broken TCP connection and reconnect. This may happen as frequent as every 20 seconds if there is no other data on the communication channel.
If you experience this problem, then you must somehow force some data to be sent back to HAGW periodically, so as to keep the channel active.
For example, you can use a clock event to send a status request to the 3rd party product periodically, or a ping/pong message. On command-line based protocols that echo all characters typed, probably sending a carriage return character is enough for getting data back to BLGW.
What to do strongly depends on the protocol of the external system.
beojeff
USA
Posts 2,012
beojeff replied on Sat, Feb 28 2015 3:23 AM
PhilLondon:
beojeff:
Yes.
Yikes. That all seems unnecessarily complicated! There are no such problems on the MLGW. It seems that the only thing lacking on the MLGW is the menu on some newer products. The built-in Philips Hue support on the BLGW is very primitive. I was considering getting a BLGW, but I'll stay with the MLGW for now. It's solid and works. The custom strings to control Philips Hue scenes work flawlessly.
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sat, Feb 28 2015 10:27 AM
Hi all
To turn this on its head is there a solution for me to trigger the door to open via something sending a url?
Or
The door relay does have the option for push to exit. I could link a relay to it if there is one that is compatible with the gateway which could accept a command to open the door.
Any thoughts
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
PhilLondon
London
Posts 3,637
PhilLondon replied on Sat, Feb 28 2015 11:20 AM
So what we've learned is... The BLGW's Custom String cannot be used for HTTP queries, while the MLGW can. At least with the current version of the software.
What I keep saying is that the BLGW shouldn't be used as a home automation system. Choose a home automation system that does what you need and interface the two (you need a driver or need to develop one).
Seanie_230
UK
Posts 2,278
PhilLondon:
What I keep saying is that the BLGW shouldn't be used as a home automation system. Choose a home automation system that does what you need and interface the two (you need a driver or need to develop one.
Hi Phil thanks for all your help with this.
I think I will find a way eventually to buy something that could trigger the relay for push to exit or program my computer to listen for a tcp message and get my of to send the Url or open the webpage which will trigger the door to unlock.
I don't really want a fully setup automation system and tried c4 before.
I think all my needs are in the BLGW with using Hue, Lutron and maybe some other devices that will appear along the way.
One thing is for sure everyone seems to be on the automation path now.
Cheers again
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Hello all
This post might need to be moved to home automation
I worked with a Bang and Olufsen engineer today and in fact a custom driver has been written and it can fire a HTTP command to unlock the front door.
This was possible in the current BLGW and BETA version.
Great news for me!
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Mon, Feb 13 2017 8:19 PM
Hi!
To send a http command was also with the „old“ firmware possible. (more on the try and error side) Can you explain how the new beta make the creation better/easier?
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Seanie_230
UK
Posts 2,278
Because you have a driver editor so you can create drivers in a much easier way for the people who can learn how to do it rather than using custom strings
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Tue, Feb 14 2017 7:31 AM
sounds exciting. thank you!
okay, now wait for the release. Cool
Page 1 of 1 (36 items) | RSS
