Adding A.DVD to my BR One
This post has 34 Replies | 1 Follower
steve1977
Posts 911
steve1977 Posted: Sun, Feb 15 2015 6:54 AM
I had added A.DVD to my Beo4 to allow it to switch to audio-only mode by the press of a button.
Is this still possible with the BR One? I have been looking through the manual, but this no longer appears possible? Am I missing something?
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Feb 15 2015 4:49 PM
I guess you'll have to select 'AV' under LIST and then 'DVD' under VIDEO. I hope 'A.DVD' is available under LIST, but I don't think so. I hope B&O didn't forget the AV command.
I would also like to replace my Beo4 with BR One. In December a dealer didn't want to sell a BR One silk although he had two of them. Even as my wife told him it would be a christmas gift for me. He told me it would be available in February. Last week I went into another B&O store during my holiday. The dealer told me BR One isn't still available alone, only with an Avant or BV11, he hoped this will change in summer. Meanwhile I don't have much interest in BR One anymore.
Regards
Räuber
steve1977
Posts 911
steve1977 replied on Sun, Feb 15 2015 8:50 PM
Raeuber:
There is no AV an no A.DVD under list per default, but it may be me not being able to program it. What is possible is to define four so called "products", which I understand is supposed for 4 different devices. The four products are called "Beo4 Video", "Beo4 AV", "Beo4 Audio", and "Beo4 Link". I am currently using the BROne in Beo4 AV mode, but can switch it to "Beo 4 Audio" and then select DVD. Maybe, that's how it is supposed to work? This would be rather cumbersome though to get into the "old" A.DVD mode. Let me give it a try.
Any idea what these four "products" are supposed to do? From what I read in the manual, it is actually for using several products (e.g., a BV and BS).
Raeuber:
I understand your frustation, but would not give up on it yet. I bought the sillk one and it is an absolute master piece. I really loved my Beo4, but the BROne is the most amazing remote ever. Hard to describe what makes it stand out, but it clearly does. I bought mine in Germany, so there are remotes out by now. Get one and you will not regret!!!
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Feb 15 2015 9:37 PM
Hi steve,
congrats that you already could get a BR One silk without buying an Avant/BV11. I tried to get one in three stores in three big cities here in Germany without success.
I also have read the manual and for me there are many questions regarding a replacement of Beo4 in a masterlink setup. Like you I also need the AV command for listening music without switching on the panel of my BV 7-40. If this would not be achieved as easy as with my Beo4 (I have AV under LIST) I wouldn't go for the BR One. So let me (and all others here) know your experiences. You are one of the first customers who tries to replace a Beo4 by the BR One, a real 'early adopter'.
Regards
Räuber
steve1977
Posts 911
steve1977 replied on Sun, Feb 15 2015 9:51 PM
It is really a great remote, so you may reconsider... ;-)
I'll let you know Tuesday whether I can get the AV feature to work. I am looking for exactly what you are looking for (playing music without panel). Worst case, this can be accomplished via p.mute, but I also don't like this option.
Related question - when switching your BV7 from DVD to A.DVD, does it also switch to stereo? This is what happens with p-mute, which is rather annoying to me.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Feb 15 2015 10:37 PM
steve1977:
The AV command switches my speakers from 5 to 2, because these are my speaker setups for video and audio. Same happens if I use P.MUTE.
At my BV 10-40 in linkroom the AV command works the same, but if I use P.MUTE the speakers stay with its setting, only the screen switches off. A litlle bit more logical but not an issue for me.
Sadly you can't use P.MUTE from standby, that's why the AV command is so important for both of us.
Greets
Räuber
steve1977
Posts 911
steve1977 replied on Sun, Feb 15 2015 10:58 PM
Can I change my speaker set-up to be 5.1 for audio as well? When you say switch to 2, does it still use the sub? I find the sub to be quite nice even for music.
You are spot-on what we are both looking for. I am as eager as you are to start music from stand-by and for this reason don't really like the p.mute function.
I checked the manual again: you can configure each of the 4 "products" (Beo4 AV, Beo4 Audio, Beo4 Video, Beo4 Link) with three different options. The options are: V.Opt, A.Opt, L.Opt. After selecting one of the 3 options, I will need to number (0, 1, 2, 4, 5, 6). Any idea what this is for and whether this helps out get something like our good ol' A.DVD back?
elephant
AU
Posts 8,219
elephant replied on Mon, Feb 16 2015 12:22 AM
On my BV8 you can set two defaults for speakers: AUDIO (say SPEAKER 2) and VIDEO (say SPEAKER 5).
So I have VIDEO set to SPEAKER 1 (centre speaker only) as mostly it is on for cooking shows & news, and AUDIO for SPEAKER 2 (stereo for my kind of music).
Perhaps your BVs have similar settings that can be adjusted to give you the behaviours you are looking for ?
BeoNut since '75
steve1977
Posts 911
steve1977 replied on Mon, Feb 16 2015 3:43 AM
Thanks. My main interest would be to get an audio-only set-up for my BV. Do you think selecting Beo4-Audio with V.Audio and 2 may get me there? The manual says that Beo4-Audio is meant for audio systems, but worth a try.
Raeuber
Germany
Posts 2,542
Raeuber replied on Mon, Feb 16 2015 9:05 AM
steve1977:
The sub is always ON with SPEAKER = 2, 3, 4 and 5. It only switches OFF when using SPEAKER = 1 (internal speaker of Beovision).
steve1977
Posts 911
steve1977 replied on Mon, Feb 16 2015 9:27 AM
Any idea what the different modes (0, 1, 2, 4, 5, 6) stand for?
Millemissen
Flensborg, Denmark
Posts 14,680
The Options of the A-, the V-, the L-setups.
Meaning: how they react to ir-commands.
Raeuber
Germany
Posts 2,542
Raeuber replied on Mon, Feb 16 2015 9:44 AM
steve1977:
Take a look into the manual of Beovision 7, pages 59, 63 and 65.
If you have a BV 7 and an audiomaster connected via Masterlink, you have to set BV 7 to V.OPT = 2 and the audiomaster to A.OPT = 0.
But this is nothing special regarding the use of BR One with Beo4-products. The options can also be set with Beo4 and if you have used a Beo4 before BR One, there has nothing to be setup again for the use of BR One.
BTW: Which B&O products do you have, a Beovision and a Beosound connected via Masterlink? Other devices in linkrooms connected via Masterlink?
Raeuber
Germany
Posts 2,542
Raeuber replied on Mon, Feb 16 2015 9:53 AM
Regarding our problem with the AV-command:
I guess this command has to be added to LIST on BR One before it can be used under LIST (like Beo4). On my Beo4 I have 11 commands available under LIST and I could add another 44 commands if I want.
It should be possible to add 'AV' to LIST because the manual of BR One says on page 16:
"Bei Auswahl eines „Beo4-Produkts“ enthält das Menü LIST auf der BeoRemote One dieselben Funktionen wie das Menü LIST auf der Beo4."
So please try to add 'AV' to LIST on your BR One.
Regards
Räuber
steve1977
Posts 911
steve1977 replied on Mon, Feb 16 2015 11:18 AM
Raeuber:
This may be bad news then. You are basically saying that the path to look to add another "product" (i.e., "Beo 4 Audio") is not the way to go? For the BV7, it would still need to be the "product" "Beo 4 AV"?
So, our solution space will be looking to add things from the list menu when having selected the "Beo 4 AV" product. I can check again, but I looked at this a few times and I don't think there is "AV" as part of this list. But let me look into this again tomorrow (I won't be back home before then).
Raeuber
Germany
Posts 2,542
Raeuber replied on Mon, Feb 16 2015 11:50 AM
steve1977:
If BV 7 is set to V.OPT = 2 you should select "Beo 4 AV" on BR One. This is how I understand the manual of BR One.
As already mentioned I think you'll have to add 'AV' to LIST. How to add functions to LIST is described on page 9 of the manual. I hope 'AV' can be added to LIST if selected the "Beo 4 AV" product before.
I hope you'll find the 'AV' command to add, otherwise BR One is not a good replacement of Beo4. Also because the AV command is needed in some other cases: If you watch videos in linkroom from sources in mainroom, audio provided via RF cable is only in mono. You can get audio in stereo by selecting masterlink cable to provide audio signals. Therefore you need also the AV command.
Regards
Räuber
steve1977
Posts 911
steve1977 replied on Tue, Feb 17 2015 11:24 AM
Unfortunately, AV cannot be added to the list. At least not in the "normal" way described in the manual. There are plenty of things that can be added to the list (both for "list tv" and "list music"), but no AV function...
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Feb 17 2015 11:35 AM
Hi Steve,
did you set BR One to "Beo 4 AV" modus first before trying to add 'AV' to LIST?
Or: Can you add video sources (e.g. DTV, VMEM) to the MUSIC LIST? So selecting DTV under MUSIC would send A.DTV!
Regards
Räuber
steve1977
Posts 911
steve1977 replied on Tue, Feb 17 2015 11:46 AM
Unfortunately, no to all of above. There are four "areas" where I can add things from the extended list:
TV - TV, DTV, DVD, V.Mem, DTV2, V.AUX, Matrix1, and some more (but no AV)
Music - Radio, CD, A.Mem, N.Music, A.Aux, USB, and some more (but no DTV, DVD, or V.xxx)
List TV - 3D, 2D, Record, Random, etc.
List - Music - Mute, P.Mute, Random, etc.
The only hope could be to try something else than "Product" "Beo 4 AV". If that's a "no", then it appears quite definite that B&O "killed" the AV functionality...
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Feb 17 2015 12:01 PM
That's very disappointing because I use 'AV' every day and really need it.
Another issue regarding this problem is the fact that the software BR One cannot be updated, so no chance to ask B&O for adding 'AV' in a software update.
I don't guess the guys in Struer 'killed' this feature. I believe they simply forgot it.
Yesterday my dealer sent me a mail that I now can buy BR One silk because he has it in stock. But without 'AV' I don't need it at all, I don't want to place to remotes on my table!
BTW: What about 'LINK', can you add this command to LIST?
steve1977
Posts 911
steve1977 replied on Tue, Feb 17 2015 12:10 PM
No "list", but as mentioned before there is a "product" labelled "Beo4 List", so I assume that this is what you may be looking for.
I also still have some hope that these mysterious 4 products ("Beo 4", "Beo4 Video", "Beo4 Music", and "Beo4 List") somehow give us the "AV" back? It appears you understand this "product thing", so any idea what it is and whether there is some hope?
Also, there are the "mysterious" product options called "V.Opt.", "A.Opt.", "L.Opt", which somehow may have some relevance? But you also appear to know what these are and they won't help us either?
Millemissen
Flensborg, Denmark
Posts 14,680
There is no 'AV'-function on NL.
The BeoRemoteOne is a remote designed with the NL in mind.
@Räuber - what makes you think, that the software of the BROne can not be updated?
P.S. Why not just stick to the good old Beo4 (w. Navi), when your products are pre-NL?
steve1977
Posts 911
steve1977 replied on Tue, Feb 17 2015 12:17 PM
Did my message just disappear? Re-typing...
There is no "link", but there is a "product" called "Beo4 Link", which may do what you are looking for.
Still two areas that give me some hope? It appears you know what they are, so maybe you can clarify whether worth to explore or a dead end:
1) "Products" - there are four different "Beo4 products": "Beo4 AV", "Beo4 Video", "Beo4 Audio", "Beo4 Link". They can be selected as different "modes" on the same level as "Beovision" (which I understand from my dealer is only relevant if I have an Avant / BV11. But there are the four Beo4 products.
2) "Product options": I can change V.Opt, A.Opt and L.Opt. We commented on the different options for this "product options": Anything to change here, which may bring hope?
steve1977
Posts 911
steve1977 replied on Tue, Feb 17 2015 12:22 PM
Millemissen:
Räuber does raise a right point though that the manual says that the manual says that all "list functions" of the Beo4 are still possible, which is not the case given our well beloved AV function is missing.
Anyhow, I do not regret the purchase and would still suggest Räuber to buy the BR One. It is the most amazing remote I have ever owned and is light years better than the also much loved Beo4. It's a true master piece!!!
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Feb 17 2015 12:25 PM
Millemissen:
There is no 'AV' on NL.
B&O itself says that BR One can replace a Beo4 and in the manual it's described very detailed. It's also mentioned in the manual that ALL list commands are available on BR One as on Beo4. The guys in Struer are sleeping all day long!
Did you detect any connection port at BR One, e.g. mini USB? If it can be updated then not by customer, but only by B&O (probably by an expensive replacement of a component).
Regards
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
BR1 updating - if the can get the original software in there, they surely can get an updated version in there too ---- somehow Stick out tongue
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Feb 17 2015 12:39 PM
steve1977:
I had notices your message very well, but look at the manual:
"Beo4 LINK wird für das zweite „Beo4- Produkt“ verwendet, wenn sich zwei TV- Geräte oder Audiosysteme in demselben Zimmer befinden."
I would need this Beo4-mode to remote my Beolink Passive which is also placed in my living room.
But if you want to get access to sources in mainroom from linkroom with BR One, you'll have to set BR One to "Beo4 AV" (BV in linkroom is set to V.OPT = 6) and need the 'LINK' command! That means if 'LINK' cannot be added to LIST also, BR One is useless for Beovisions in linkrooms!
steve1977
Posts 911
steve1977 replied on Tue, Feb 17 2015 1:58 PM
Mis-understanding - one previous message of mine was never shown in this thread. No clue why.
Anyhow, it appears that there is indeed no "AV" function anymore with the BR One. It is how it is. Would still suggest you give the remote a try (with p.mute instead). I am sure once you start using it, you will never go back to the Beo4...
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Feb 17 2015 2:55 PM
I actually called my dealer and he confirmed that the 'AV' and 'LINK' commands are not available under LIST on BR One. BR One could be a neat solution for a stand-alone video- or audiosystem but not for me as an owner of a large masterlink system. So he recommended me not to replace my Beo4 with a BR One. BR One would be a perfect remote for the new Beovisions, but Beo4 is indeed still much better for the old masterlink systems.
Another point is that Beo4 has 7 hardkeys for direct access of different sources, and I need all 7 keys. On BR One there are only 5 hardkeys (3 Mybuttons and MUSIC and VIDEO). That's why I would have to group some sources under MUSIC and/or VIDEO.
Another drawback of BR One is that there is no space between the buttons, usage in the dark is not as easy as with Beo4, because B&O had 'forgotten' to illuminate the buttons.
At the end of the day my decision is: Stay with Beo4 and be happy!
Greets
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
So - after all - you listened to my advice from above Big Smile
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Feb 17 2015 5:48 PM
Hi MM,
BR One could be a great successor for Beo4 if 'AV' and 'LINK' commands would be available, even for use with masterlink products.
Meanwhile I understand why these commands wouldn't work with BR One:
On Beo4 you have to press LIST until AV or LINK appears on display and then you have to press a source button. This is problematic with BR One because if AV or LINK would appear on display you normally cannot select a source directly but have to press MUSIC or VIDEO and then a source list will appear on display and AV or LINK would disappear. This may be the dilemma and the reason why B&O 'killed' these (for me) essential commands. And as we know at least since the presentation of the Moment, software development is NOT a key feature of the guys in Struer.
Greets
Räuber
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Feb 17 2015 6:28 PM
steve1977:
Sorry for these late answers:
1) See manual page 16
2) V.OPT: Option setting for video products
A.OPT: Option setting for audio products
L.OPT: Option setting for link products
(only relevant for the products, no affect for the remote itself)
Both will not help to get 'AV' and/or 'LINK' on BR One, that's for sure.
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Feb 24 2015 9:39 AM
Meanwhile I got a BR One. It's possible to switch on a Beovision in audio mode without switching on the panel (AV command).
With my masterlink system BR One is not a good solution because you have to set Beovision in main room to 'Beo4 with navi button'. But then I have problems with my Beovision in linkroom to remote BV in mainroom with my Beo4 without navi button. The only solution would be to buy a Beo4 with navi button for Beovision in linkroom, to buy another BR One for linkroom wouldn't be a solution because the lack of LINK and LINK-AV commands on BR One.
I decided to bring back BR One to my dealer. BR One is a nice remote with excellent build quality but Beo4 is still easier tu use, especially with older Beovisions. In the dark you find every button on Beo4, but not on BR One.
Regards
Räuber
steve1977
Posts 911
steve1977 replied on Tue, Feb 24 2015 10:01 AM
Thanks. Can you elaborate more how you use the "AV command" to switch on a BV in audio mode?
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Feb 24 2015 10:50 AM
Hi steve1977,
ok, I will try although I don't have BR One anymore:
First I guess you had set your BR One to 'Beo4 AV' mode (shown in first line of BR One's display), so you can remote your Beovision and your BC2 connected via masterlink. Second you added 'DVD' to your VIDEO source list.
Please add 'Beo4 AUDIO' to your Beo4 products (manual, page 16).
Send A.DVD as follows:
Press LIST on BR One
Mark 'Beo4 AV' and press the round button
Select 'Beo4 AUDIO'
Press VIDEO
Select DVD
If you want to remote your system then in 'normal' way, you have to change the mode from 'Beo4 AUDIO' to 'Beo4 AV' again.
Not so easy in daily use, but it works, because in 'Beo4 AUDIO' mode BR One always sends 'AV' before the selected source command.
Good luck!
Räuber
Page 1 of 1 (35 items) | RSS
