Beocenter 2 problem ?
Soren
Luxembourg
Posts 2
Soren Posted: Tue, May 29 2012 5:21 PM
Hi all,
Today I noted that the red light in the display (indicating on/off) on my Beocenter 2 is flashing all the time.
Even if I turn the power to it off and on again. As soon as it is on, the light starts flashing again.
There is nothing in the manual indication reasons for a flashing red light, except where is says is flashes when I touch a button or turn the wheel.
Does anyone know what the reason can be, or know where I can find supplementary information about it ?
Regards
Soren
beojeff
USA
Posts 2,012
beojeff replied on Tue, May 29 2012 6:29 PM
It certainly sounds like the power was disconnected for an extended time and the PIN code has to be re-entered. The PIN code is 4 digits long.
Soren
Luxembourg
Posts 2
Soren replied on Wed, May 30 2012 5:28 AM
beojeff:
Indeed it was the pincode that needed to be entered again.
Thank you for the help !
gk31ax
Posts 19
gk31ax replied on Wed, Dec 23 2020 6:17 PM
Today I have the same problem.
The PIN request came up on the screen and then disappeared as I had to go an find it....
Now all I get is a flashing red light!! I try putting in the PIN on the unit, nothing? Have read somewhere that I should probably power it off for 3 hours and try again, will try that as well.....
My dealer went bust of course, so any ideas from the forum in case this doesn't work?
Cheers
Gary
gk31ax
Posts 19
gk31ax replied on Thu, Dec 24 2020 10:26 AM
Turned the power off overnight, reconnected everything and still the same problem.....
Any ideas?
CB
> You are Here <
Posts 1,762
CB replied on Fri, Dec 25 2020 3:07 PM
Hi
If your Beocenter loses memory, it could also be a battery problem.
gk31ax
Posts 19
gk31ax replied on Mon, Dec 28 2020 5:21 PM
Thanks - how do I replace the battery?
CB
> You are Here <
Posts 1,762
CB replied on Mon, Dec 28 2020 7:51 PM
Sorry, I don’t know Huh?
My BS Ouverture showed weird behaviour and it was because of the battery...
Page 1 of 1 (8 items) | RSS
