Can someone explain how to tune the radio in BM7000 with Beo4 and store in presets.
I have forgotten as it is so long ago that I had to do it.
Regards Graham
It is somewhere on the forums and I have no idea where - but the core of the trick is to put the Beomaster in option 2 so that it will follow video commands as well, and then you can use the TUNE command that is found in the list of Beo4 (but only in video mode). I think you had to cover the remote while you press TV so that the Beomaster doesn't know what comes next, then dig up TUNE.
Buy a Beolink 1000
--mika
Aaah! Option 2! That's what I forgot.
It works now!
Aaah! Option 2
what is option 2 ? How do put the beomaster into option 2? with a BEO4?
