The Moment software version Release Notes
This post has 749 Replies | 13 Followers
YannChris
Larmor Plage - France
Posts 232
YannChris replied on Sat, Dec 12 2015 9:13 PM
Hi Beroli,
Here is my chart updated (removed Beoport).
Unfortunately, the IR eye is delayed to January.
Thanks for your help,
Yann.
Living Room   BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge  Beolink Passive - Cabasse Clipper - Beo4      Kitchen  BL3500 - Beolink 1000
Bedroom    BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge   BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study    BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
elephant
AU
Posts 8,219
elephant replied on Sun, Dec 13 2015 6:08 AM
Does the BLC show up on BeoSetup ?
After configuring does it show up on BeoMusic ? (in my setup the BLC is named BeoLink by me)
BeoNut since '75
YannChris
Posts 232
YannChris replied on Sun, Dec 13 2015 6:27 AM
Hi Éléphant,
Yes to both questions.
Kind regards,
Yann
elephant
AU
Posts 8,219
elephant replied on Sun, Dec 13 2015 6:33 AM
YannChris:
Hi Éléphant,
Kind regards,
Yann
What is the black LS link between the BLC and the BL2500s in the study ?
Edit:
Sorry not BLC but NL/ML converter ???
BeoNut since '75
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Dec 13 2015 6:35 AM
Beroli:
Please have a look on the previous posts - maybe I was not specific enough. The 15 s lag is not the exception it's the all-day experience for me now. There was a time, that most bugs were related to my own content - Deezer was always great to use. Now it's kaputt.
Hi Beroli
I'm sorry, my misunderstanding.
I'm surprised in the 15s lag you have with Deezer, your Moment must be indeed 'kaputt'.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
YannChris
Posts 232
YannChris replied on Sun, Dec 13 2015 7:18 AM
Elephant,
It is a RJ45 to Powerlink cable.
It is a NL/ML converter delivered on friday with the Moment. Here are screenshots if it may help.
Thanks and best regards,
Yann.
elephant
AU
Posts 8,219
elephant replied on Sun, Dec 13 2015 7:41 AM
I'll compare with my settings after dinner ...
BeoNut since '75
lonfred
Posts 200
lonfred replied on Sun, Dec 13 2015 11:44 AM
I have a simular setup. Since I never used analouge radio or the CD-player I removed my BC2 from the ML-network and set the BLC in A-master mode. It work really good and I have assigned the Tunel radio to the Radio Button an the Music to the CD button so no need to use the list button anymore on the Beo4. The BC2 now only work as a DVD player to my BV10-46 via scart. Everything works really good. The Moment is a dream compared to my old setup with BC2 and Beoport. I have never had any problem with the Momemt so far the only thing that I really miss is the timer function that my BC2 had. Hopefully BO will integrate a timerfunction again.
Beroli
Germany
Posts 316
Beroli replied on Sun, Dec 13 2015 11:58 AM
Hi Yann,
just had a look on your very nice setup. It's quite a collection - the best products from several generations.
May I ask why you decided to configure the NL-converter as source? Is it because you wanted to attach speakers and the ir-eye to the Converter? Could you please try to set-up the Converter as a A-Master. In this setting the Converter is able to manage more than just one Audio-devices. In my case the converter is managing the Moment and the BeoVision (incl. the 5 speakers) in the Living-Room and the Essence in the office with speakers attached. Now I can even join/start with my BV in the Living-Room the content-sources (Deezer, TuneIn, NAS) from the essence, without using the Moment at all.
Just try A-Master, then first source the Moment, second source your BLC. I don't know if this will work, but I got the feeling, that you can't use more than 1 audio-master, if you set it as source. Maybe elephant is proofing me wrong 😉.
When you compare the BeoLink Converter NL/ML setup examples from the manual page 26 and 28, it seems to me that the setting as A-Master, instead of source-center, would be better for your setup.
Cheers Beroli
PS: sorry Chris, that we spoil your original thread. Maybe we should ask for a separate NL/ML-Converter section. I promise as soon the new update is showing up, we will have to write much about it.
Beroli
Germany
Posts 316
Beroli replied on Sun, Dec 13 2015 11:59 AM
Oh ionfred was faster, with the same thought.
Giraffe
Posts 37
Giraffe replied on Sun, Dec 13 2015 12:17 PM
Hi Beroli,
I'm under the impression that you cannot have the BLC configured as an A-Master if you have another A-Master already. I tried it with my setup which includes a BS3000 and found that if you press eg. Radio both the Moment and the BS300 are playing simultaneously.
Or is there a way to get around that effect?
Giraffe
lonfred
Posts 200
lonfred replied on Sun, Dec 13 2015 1:18 PM
I belive that you can still have the BC2 connected to the BLC in A-master mode if you dont assign any other sources on the same sources that the BC2 is given. I have not tested this but I cant see why it would not work.
Beroli
Germany
Posts 316
Beroli replied on Sun, Dec 13 2015 2:02 PM
lonfred:
I can confirm ionfreds statement, because I use it in my setup. You can assign for example Radio with Radio on the BS 3200/3000 and N-Radio (or N-Music, A-Aux...) to TuneIn on the BS-Moment. If you use for example the BeoRemote One you can even rename N-Music... afterwards.
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Dec 13 2015 2:03 PM
Hi Giraffe,
Sorry to fall in on your message.
I had also a BS3200 before I removed it to the basement. The only solution was to point the Moment's radio to N.Radio. Removed the BS3200 because: not using CD's anymore and felling not comfortable with pointing my remote everytime to N.Radio.
Beroli
Germany
Posts 316
Beroli replied on Sun, Dec 13 2015 2:13 PM
Chris:
That's why I am very comfortable with the BeoRemote One. In the first place I hated the keypad, now I am used to it like with my old beo4. On the Beoremote One you can change almost everything. Names, Positions - you can even assign Quick-buttons. This remote is real B&O magic - for me.
Here is a example for A-Master
Giraffe
Posts 37
Giraffe replied on Sun, Dec 13 2015 3:04 PM
Beroli:
Hi Beroli and ionfred,
good catch! That means as long you assign the Moment to n.music and n.radio there is no conflict. However those are just the two options left for free configuration if you choose "Source Center". What advantage is then left for choosing A-Master?
Thanks for mentioning the tricks that are possible with the BROne! This might be a trigger for me to purchase one.
Giraffe
elephant
AU
Posts 8,219
elephant replied on Sun, Dec 13 2015 3:22 PM
BeoNut since '75
Beroli
Germany
Posts 316
Beroli replied on Sun, Dec 13 2015 4:29 PM
Hi Giraffe,
the advantage lies therein, that you will have more freedom, how about you want to use your setup - but at some point, as Chris wrote, you will have to decide which audio-system will be your primary device. I replaced the BS3200, mostly of the same reasons, like Chris. There are still some issues (Moment/Converter) to figure out. For example, you have to do the setup in a special order to get the "join"-function working properly. I am still waiting on the feedback from BeoCare about this.
If the BS-Moment (hopefully) matures in the future, you will use it more frequently than your "old" system - and you will take away more functions from your old devices. For example - since TuneIn there is no need for radio on the BS3200 anymore - you could assign Radio from the BS3200 to a new/old device or source.
Beroli
YannChris
Posts 232
YannChris replied on Sun, Dec 13 2015 7:49 PM
lonfred:
Ionfred,
During installation, I removed the Beoport and N Music and N Radio from the BC2 option.
Selecting "asking" N Music on the Beo6 turns on the Moment.
In your opinion, setting the NL/ML Converter as Audio Master would still work and enable me to use the converter in another room with speakers?
Kind regards,
Yann.
Giraffe
Posts 37
Giraffe replied on Sun, Dec 13 2015 8:19 PM
Beroli:
Hi Giraffe,
Beroli
Hi Beroli,
I already use the Moment every day - there is definitely room for improvement but I would not want to give it away again. The concept really fits my needs. I am just curious to learn something new about the BLC and its optimal configuration. To date I cannot bring it over me to fully discard the BS3000 - while I have to admit that listening to CDs is only happening on very rare occasions these days.
Giraffe
lonfred
Posts 200
lonfred replied on Mon, Dec 14 2015 7:43 AM
Yann, sorry but I dont have the answer for that question. Maybe not in A-master mode.
Chris
Ostend-BE
Posts 1,170
Chris replied on Wed, Dec 16 2015 4:56 AM
Waking up this morning and noticed a new sw update for the Moment, its now on version SW 1.5.5.1110-1.5.342.222427666
Lots of improvements according to the release notes.
I noticed B&O is also trying to improve their system on low quality networks. Together with the NAS connection improvements it could be the solution to customers who are struggling with this kind of faults, hopefully.
Beroli
Germany
Posts 316
Beroli replied on Wed, Dec 16 2015 7:05 AM
Hi Chris,
are you sleeping on the device? Yes - thumbs up You are always the first. Big Smile Thank you for the update on the new sw-update. I got the information it will be out before christmas - but I wasn't expecting it so soon. Lets have a Party !!! I will test it for sure on the weekend - since my whole Living-Room is recently a construction-site and I had to remove the whole B&O-setup Crying.
BTW: the Essence MK2 got a new update as well: version: 1.3.285.180654312
Cheers Beroli
Brigantinus
Posts 140
My first impression: Much smoother and cover are loaded faster. I think that's the "improved connection to the hub".
Big SmileBig SmileBig SmileBig SmileBig Smile
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Dec 16 2015 8:23 AM
Can anyone publish the release notes? They are supposed to be on the site, but I cannot find them.
I´m at the office currently and curious Smile
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Dec 16 2015 9:13 AM
I'm ready now to capture network traffic (new Netgear managed Ethernet switch with port mirroring + Wireshark) so perfect timing for this update.
Chris
Ostend-BE
Posts 1,170
Chris replied on Wed, Dec 16 2015 11:03 AM
Beroli:
Big Smile Guess I was lucky, and I'm an early bird.
Hiort:
Version SW 1.5.5.1110-1.5.342.222427666 is introducing the following:
- Linking or borrow sources is now possible with BEOremote One, it means you can now ‘borrow’ the sound source from another product (TV) standing in another room, even as the product is in to standby mode. The product will be activated in silent mode and sends sound to the Moment.
- The warning icon has now extensive information.
Further upgrades done to the software:
- Volume
- Connectivity between Hub and Interface
- Intercourse with TuneIn
- Solution to the problem with music storage/NAS in selecting.
- Solution to the problem with integration of a MasterLink TV
- Artist name now appears in linked Beolink Multiroom devices.
- More reliable signal distribution in Multiroom, even within networks of lower quality.
Millemissen
Flensborg, Denmark
Posts 14,680
'- Linking or borrow sources is now possible with BEOremote One, it means you can now ‘borrow’ the sound source from another product (TV) standing in another room, even as the product is in to standby mode. The product will be activated in silent mode and sends sound to the Moment.'
This is probably the reason for the update on the tv's a couple of days ago!
Another thread on the forum claim, that B&O is 'going down the drain'.
I'd say these updates prove that B&O is very much alive and kicking ;-)
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Dec 16 2015 1:00 PM
Chris:
Hopefully one day the source will also be identified M(usic) D(eezer) in both the Jukebox and the Multiroom devices.
PeterBOBP
Posts 133
PeterBOBP replied on Wed, Dec 16 2015 1:15 PM
Yes, all problems related to artist and album covers are solved in this release; added albums / artist from Deezer / Twonky now appear almost immediately. Also the volume control seemed to be more responsive.
A quick test around the "middle" or second ring in the mood wheel seems to indicate that they improved that as well; it looks as though it is better at taking into account my music taste and it  now at least occasionally plays a song that is in my library; further testing needs to be done to be sure.
So all in all it the Moment from me went from "Good" to "Excellent"
lonfred
Posts 200
lonfred replied on Wed, Dec 16 2015 6:04 PM
Now the only missing thing is timer-event function that could work with BLC and ML then it would be completed. But maybe its just me that are missing that thing?
Vintage_B&O
Germany
Posts 303
I am missing a function to see my compilations or my albums. I have many compilations and it is terrible to start one album.
A question to all Qnap / Twonky Users: Habe you switched the Twonkey Server to "Bang & Olufsen" or to "Generic Media Server"?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Dec 16 2015 7:29 PM
MircoHH:
Personally I have set "Enable sharing for new media receivers automatically" but I have seen the SoundHeart registering itself as Generic Media Server / Mobile or B&O.
I have just done a Devices/Reset List, start to play from the Music source and the SoundHeart self-register as Generic Media Server/Mobile which is OK for me.
Seanie_230
UK
Posts 2,278
The interface is really snappy and volume control works great no more jumping in volume after the command is received and then pass to the base
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Chris
Ostend-BE
Posts 1,170
Chris replied on Tue, Dec 22 2015 7:34 AM
Actually not many bad responses after this latest update, that must be a boost to the R/D team at B&O.
I can accept PetrBOBP’s opinion as mentioned in his reaction that the Moment now went to ‘excellent’. My Moment acts and reacts now flawlessly in the whole of my system. The child is getting mature.
Starting this morning one of my own playlist I made on the server and to my surprise I noticed that the list not started with the same first music track anymore, it picks immediate a random track out of the list. I have to investigate this better, should B&O fulfilled my wish for the random play?
Edit: To quickly shouted hurray, for what reason ever the playlist started with another track that I'm used to hear. Stopping the list and starting again still gives me that same track, as this track ended it goes to random. As usual.
The only thing which worries me a bit is tuneIn, on some radiostations they begin to sent abundant local advertising very often. Will this be the beginning of another payed application to all users?
I'm glad I've had continued confidence over the passing year in this new music player and their new network link, now that the research team got the software right in my opinion, we can start looking for some new applications to add. My fellow forum members, this is not an advertising more a statement: I really enjoy the sound, and handling of this new music system from my favorite brand.
seethroughyou
UK
Posts 999
How is at playing ones own collection of ripped CDs? I prefer my collection of classical music to Deezer.
Is the search function from your NAS working now?
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Dec 22 2015 9:14 AM
Chris:
Agree with your post.
Some things to add for coming releases:
- Add something to distinguish an artist tile from an artist on my NAS from the same artist in my Deezer playlists in the Jukebox interface.
- Enable user to add artwork for Artist tiles where that is missing.
- Select random play of all songs from an artist I have on my NAS from the Beomusic app (I know, this is not a Moment feature Smile )
- Gapless playback
- Deezer Elite
- Search in NAS content
- Enable more DLNA servers than Twonky
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Dec 22 2015 9:15 AM
seethroughyou:
No
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Dec 22 2015 9:17 AM
Chris:
Chris,
How do you recommend that I create playlists? I assume that it is playlists covering songs from your NAS, right?
Chris
Ostend-BE
Posts 1,170
Chris replied on Tue, Dec 22 2015 9:30 AM
Hiort:
Hi Hiort,
My hurray was to early for playlists, I edited my last post.
I create the playlist with VLC on the music server with remote desktop (its not a NAS) and save them as m3u extension. Could do it also from a distance on my PC, but then I have to put in the right directorys.
An example:
#EXTINF:258,Abdullah Ibrahim - Peace
/Users/iTunes/Music/Jazz/Abdullah Ibrahim/Mukashi Once Upon A Time/06 Peace.flac
#EXTINF:274,Abdullah Ibrahim - Matzikama
/Users/iTunes/Music/Jazz/Abdullah Ibrahim/Mukashi Once Upon A Time/07 Matzikama.flac
#EXTINF:187,Abdullah Ibrahim - Cara Mia
/Users/iTunes/Music/Jazz/Abdullah Ibrahim/Mukashi Once Upon A Time/08 Cara Mia.flac
#EXTINF:220,Abdullah Ibrahim - Root
/Users/iTunes/Music/Jazz/Abdullah Ibrahim/Mukashi Once Upon A Time/09 Root.flac
#EXTINF:340,Abdullah Ibrahim - Trace Elements For Monk
Page 8 of 19 (750 items) « First ... < Previous 6 7 8 9 10 Next > ... Last » | RSS
