BLGW Beosound 4
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Tue, Feb 24 2015 7:23 PM
Hi there all
I setup my beolab gateway originally with my bv7 and Beosound 4.
I was trying to get it to work with my beivision 3 and 6.
The beivision 6 I could control but after a few days I lost control of the Beosound 4 when trying to activate from the zone it sits in.
I can call up the sources from the main room zone fine. I have removed the resource and added again via capture but still don't seem to have gained control via the app?
Any thoughts?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
PhilLondon
London
Posts 3,637
Have you done a ML re-sync?
Beoworld app with direct photo upload and emoticons.
Seanie_230
UK
Posts 2,278
PhilLondon:
Have you done a ML re-sync? Beoworld app with direct photo upload and emoticons. Other apps: The Story Mouse . Grignan guide .
Hi Phil
Thanks for all the ongoing help.
I did one last week when testing could that have affected my option settings?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Tue, Feb 24 2015 10:54 PM
Sounds like the bs4 is in option 0.
If put it back in the correct option and
Test again.
Seanie_230
UK
Posts 2,278
mjmedlo:
Test again.
Hi there
I had to change its option and change it back and it is now fine :)
Weird but fixed :)
Ready for the essence now.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Hi all
So control is working via the Beosound keypad and the app and the speakers play sound.
I have noticed annoyingly that the standby button single press turns off the TV in the main room also.
I have also noticed when setting up my essance remote today in light mode the light and control commands are passed via the TV in the next room and the Beosound 4 does not even see any IR.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Hi all
After I changed the option I now have control via BLGW but also when I turn the stereo on via its own buttons it turns on tr TV in the other room and plays via the speakers.
The below document I think shows that BS4 can only work with the Beosound 4 if it's connected via the BV7.
If you look at the * statement I think this means the audio master will only work if it's in the option that means it's controlled by a video master.
Any thoughts
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (7 items) | RSS
