All,
have any of you used the Lat/Long of your BLGW as a trigger for a command?
I understand, from my dealer, that you can use the whereabouts of your BLGW to
trigger scenes, I.E. 5km from my house and coming closer, turn on a scene.
I can't figure out how to do this. . .anyone know?
The Lat/Log is to compute the sunset/sunrise times. The BLGW doesn't really move. does it?
Beoworld app with direct photo upload and emoticons.
well my blgw is attached to the back of my pet elephant. . .j/k j/k
I want to set up a macro where when i'm closing in on the location of my blgw a scene triggers..
maybe this can't be done?
It was said the BLGW will soon get a support for ifttt.com
ifttt.com allows you to create many automated rules, based on trigger, one of this trigger is location. You need to download and install an app on your phone for it to work.
P.
Philips Hue currently has this capability, which it calls "geofencing." However, there is not yet a way to use Hue as a trigger.
