PUC code for Optus Fetch TV box (Australia)
beolion
Posts 485
beolion Posted: Tue, Mar 3 2015 11:14 AM
Hi
I can not find the updated list of PUC codes and I just would like to know if there exist a PUC code to control the Optus Fetch TV box.
Thanks.
beoaus
Posts 177
beoaus replied on Mon, Apr 3 2017 1:42 AM
Did you receive an answer? I just posted the same question.
Thanks, beoaus.
Yendys
Sydney
Posts 312
Yendys replied on Mon, Apr 3 2017 2:41 AM
I know there are codes for Humax HDRs and various people on the forum are using them. That is what I might go to in Oct
beolion
Posts 485
beolion replied on Mon, Apr 3 2017 3:15 AM
I asked B&O down here, and they said no, and also that Fetch uses radio and not ir which I don't believe since I have to point the remote every time.
And I could not figure out what other box would be similar in regard to PUC codes.
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
