beo 5 nightmare HELP
This post has 5 Replies | 2 Followers
craigleessss
Posts 3
craigleessss Posted: Thu, May 31 2012 5:01 PM
hi everyone i have a beovision 7 (mark 2 , 2006) with a sky hd box attached via the v.aux socket,my problem is that in the beo5 configuration tool i can only drop logos into tv ,radio or dtv but i want the logos in the v.aux where my sky is plugged into so when I press v.aux my sky logos (uk gold etc ) are sorry if this is confusing hope anyone can help
cheers Craig
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, May 31 2012 5:38 PM
No nightmare at all....
You can change the IR command of your TV (DTV) key to AUX_V. And change the label of the button to V.AUX.
Or make a copy of your TV logo page and assign it to the V.AUX button if existing. If not create a new one.
You find a help menu on the right side of the config tool.
Hope this helps
Stefan
craigleessss
Posts 3
hi stephan thanks for your reply
for the last 15 hours I have tried to sort out my problem my wife as gone mad anyway your post made me leep with joy unfortunaley because of the size of my pee brain I tried to change the IR IN THE NEW BUTTON MENU and it all went pear shaped  and wouldnt finalise could you take me through it button to button otherwise my wife is leaving  with the milkman
or tell me how to assign a logo to the v.aux button
thanks for your help
Craig
stefan
Posts 2,920
stefan replied on Fri, Jun 1 2012 9:00 PM
15 hours are too much for changing a button...:)
Open your configuration - select Edit - right click the button (TV?) you want to change - select Properties - change TV to V.AUX in the button text field - select IR - delete IR command (0:000:TV:TV) - select AUX_V from the list (you can type AUX in the command field) - select AUX_V (V.AUX) - press Add - press OK - now select Finalize and download the new configuration to your Beo6 (if connected to your PC...)
You can make a copy of your original TV button before change - right click TV - select Copy - the TV button will be copied to the button clipboard.
Hope this helps
Stefan
craigleessss
Posts 3
Stefan you are an absolute life saver thank you so much for saving my sanity , marriage,and a smashed up remote control
really thank you very much.       it works perfectly !
Craig
stefan
Posts 2,920
stefan replied on Sat, Jun 2 2012 12:16 PM
Wow - less than an hour! That`s what Beo-experts call "speed-programming"... Congratulation!
So we learn that a correctly programmed Beo remote can not only change your life, it also can save it !!:))
Enjoy your Beo5 and your life
Stefan
Page 1 of 1 (6 items) | RSS
